-1
So my original problem was that I couldn't get the ubuntu software centre to startup, it would just freeze for a while loading and then would crash.
So i tried to remove USC : Successfully
When I came to re-install I ran into a problem with the sudo-apt install / get and loads of other commands.
This is what i get when i enter sudo apt-get update
E: Malformed line 56 in source list /etc/apt/sources.list (dist parse)
E: The list of sources could not be read.
I looked into the folder /etc/apt/sources.list.d/ and there seems to be no source list file, however there appears to be one in its parent folder.
I'm still new to this and I couldn't find a solution anywhere on the forums. Help is greatly appreciated :)
Thanks !
open a terminal and type the following command
sudo gedit /etc/apt/sources.list
Now, scroll down to line 56. There is your problem. What is different about this line? Is there a typo somewhere? Did you add this line manually?
To get around this problem, you can delete this line or comment it out by placing a # at the beginning of the line. After fixing the line, removing it, or commenting it out, save the file.
After saving the file run this command:
sudo apt-get update
There should be no error anymore.
To apply updates, run these commands:
sudo apt-get upgrade
If it mentions any packages held back, you can run this command to install them:
sudo apt-get dist-upgrade
mchid
  • 44,904
  • 102
  • 162
