I usually preferred some fonts which are not available in Ubuntu 14.04 viz. Times New Roman, Arial etc. How these fonts can be installed in Ubuntu 14.04 environment ?
Method 1) Open Ubuntu Software Center and search for "ttf-mscorefonts-installer". This will install Microsoft's core fonts.
(Note: downloading ttf-mscorefonts-installer from ubuntu download centre,does not properly install the fonts because Microsoft's license is not accepted) so it can be install only from the terminal)
sudo apt-get install ttf-mscorefonts-installer
then accept the Microsoft's license using tab key in a graphical interface during install.
After installing the font package you will need to update the shared font directories with the following command in a terminal shell.
sudo fc-cache -f -v
[ttf-mscorefonts-installer is included in Ubuntu-restricted-extras and the common practice is to install them together with video codecs, flash,etc. sudo apt-get install ubuntu-restricted-extras]
Method 2) Create a directory into your home folder, and name it ".fonts". In this folder you can copy all fonts from Windows (C:\WINDOWS\Fonts).
Mudit Kapil
  • 2,081
Xover
  • 201
Navigate to the location of the downloaded fonts, then make sure they're unzipped (if they were in a compressed folder). After that, double click one and a window with a preview of the font will appear. There should be an "Install" button in the upper right corner. Click it to install the font.
