I've downloaded some gopro footage to my local hd and then copied the files from my hd to an external drive. Whenever I want to change the access rights it will switch back to read only in Nautilus. Likewise if I change the ones for the files below. How can I give full rights? I need to process the footage on a mac.
sudo parted -l /dev/sdb
Modell: JMicron Generic (scsi)
Festplatte  /dev/sdb:  500GB
Sektorgröße (logisch/physisch): 512B/512B
Partitionstabelle: msdos
Nummer  Anfang  Ende   Größe  Typ      Dateisystem  Flags
 1      1049kB  500GB  500GB  primary  ext2
empedokles
  • 4,023
From this line
/dev/sdb1 on /media/nuc/500GB type fuseblk (rw,nosuid,nodev,allow_other,default_permissions,blksize=4096)
I see that external drive filesystem is NTFS and it was by default mounted without respect to NTFS permissions. In this case all files/directories will have the same permissions and attempts to change them will be ignored.
I have solved similar problem by making permanent share with explicit settings:
write line
UUID=C848-2413 /mnt/E_DRIVE vfat rw,user,exec,umask=002
into /etc/fstab where UUID is from sudo blkid. (Then mkdir /mnt/E_DRIVE, setting permissions, then umount / mount.)
Simpler alternative is to install special tool:
https://apps.ubuntu.com/cat/applications/quantal/ntfs-config/
