I was creating a wifi hotspot using kde-nm-connection-editor as instructed on Share Internet Connection With Android in Ubuntu 14.04 but an unexpected error occurred as a result of which I was able to create it up. The following error appeared :
(32) Access Point (AP) mode is not supported by this device.
Asked
Active
Viewed 3,472 times
Novice
- 550
As @Zeiss Ikon said, it seems that it doesn't support AP mode. Sadly this happens to me too.
You can run in a terminal iw list and check the Supported interface modes: section to see if there is any reference to AP. If not, then you can't use the AP mode.
Diosney
- 298
That error is reporting that your particular wifi hardware doesn't support operating as a hotspot. There's nothing you can do in software to correct it, you can only replace the hardware (though it would probably cost about the same to buy a cheap wifi router).
Zeiss Ikon
- 5,248
