I've got Toshiba Satellite U50t-A-10H with Win8.1 installed, UEFI, HDD 750GB + 32GB SSD cache.
I'm trying to install Ubuntu on it. I've split my disk, made 200GB free unallocated space and booted Ubuntu USB. I proceeded with settings to install Ubuntu and I've got to stop on the partition manager page where I needed to choose disk where it should be installed. Nothing was there. No drives, just blank window. When I clicked on some button or on Install button the whole installation window freezed.
Ubuntu partition manager in liveUSB Ubuntu alerts that there is something wrong with drives and wants to fix or ignore the problem. When I ignore it, it starts normally and sees the whole 750GB disk as one drive with ! next to it.
Switching from UEFI to CMS mode doesn't help, same problem.
First I wanted to do dual boot but I'm OK with formating the whole disk and installing only Ubuntu. How could I do it? Does anybody know what the problem could be?
EDIT:
output sudo fdisk -l (if it helps):
Disk /dev/loop0: 1 GiB, 1115594752 bytes, 2178896 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/sda: 698.7 GiB, 750156374016 bytes, 1465149168 sectors
Disklabel type: gpt
Disk identifier: F563326D-2568-11E3-982D-B69BBCB9388F
Device Start End Sectors Size Type
/dev/sda1 2048 2099199 2097152 1G Windows recovery environment
/dev/sda2 2099200 2303999 204800 100M EFI System
/dev/sda3 2304000 2566143 262144 128M Microsoft reserved
/dev/sda4 2566144 1035055103 1032488960 492.3G Microsoft basic data
/dev/sda5 1444655104 1465143295 20488192 9.8G Windows recovery environment
Disk /dev/sdb: 29.8 GiB, 32017047552 bytes, 62533296 sectors
Disklabel type: gpt
Disk identifier: A2D2106D-3D45-11E3-8254-5C514F51D303
/dev/sdb1 2048 23523327 23521280 11.2G Intel Fast Flash
Disk /dev/sdc: 14.9 GiB, 15997075456 bytes, 31244288 sectors
Disklabel type: dos
Disk identifier: 0xc3072e18
Device Boot Start End Sectors Size Id Type
/dev/sdc1 * 8064 31244287 31236224 14.9G c W95 FAT32 (LBA)
