33
Is there a standard procedure to 'unit test' an Ubuntu system against the deb packages?
Assume, a system has ubuntu-desktop installed according to the package manager. Can I find out, whether the file system has all the files in ubuntu-desktop and dependencies?
related question: Find packages with corrupted files
David Foerster
  • 36,890
  • 56
  • 97
  • 151
Jan
  • 3,658
For the most part, deb packages come with a md5 file containing signatures of all files in the package. These files are located at /var/lib/dpkg/info/$pkg.md5sums.
To simplify the periodic check of all installed packages, the debsums package can be of help. Install it, clean the cache with:
sudo apt-get clean
then run sudo debsums_init to generate md5 sums for packages that do not provide them (the packages are downloaded to generate such sums).
Next, edit the file /etc/default/debsums and set CRON_CHECK=weekly to configure a cron weekly job for the check of debsums.
You can run the check manually with the command:
sudo debsums -cs
Regarding the integrity of the dependencies, I suppose that the command:
sudo apt-get -f install
should signal and try to resolve any problem it finds relative to installed packages, but the Debian/Ubuntu package management system is a very complex object, and could be very difficult to find and resolve its problems.
slm
  • 3,155
enzotib
  • 96,093
