Does anyone know if this is possible, and if so, what installation options I should choose?
To change your install to boot straight to command line after install, you can just Go to a terminal prompt..
gksudo gedit /etc/default/grub
Then make the following changes..
Change the lines containing..
GRUB_CMDLINE_LINUX_DEFAULT=”quiet splash” .. just put a # at the beginning
GRUB_CMDLINE_LINUX=”" to GRUB_CMDLINE_LINUX=”text”
#GRUB_TERMINAL=console to GRUB_TERMINAL=console
Save and exit.
sudo update-grub
That will stop X from starting on boot. to start X, just type startx
- 2,646
- 16
- 20
Are you talking about the Ubuntu server edition? Follow the instructions on that page (or this one from the 12.04 Server Guide) to install it, similar to a regular Ubuntu install but text-based.
And then install a desktop environment with a line like sudo apt-get install ubuntu-desktop, or sudo apt-get install xfce4 (the "Meta-package for the Xfce Lightweight Desktop Environment").
You could pick whichever desktop environment you prefer, there are a LOT to choose from. I'd pick XFCE. See What kinds of desktop environments and shells are available?
