I don't want to use the Super for that, I want to use Alt+Space instead.
αғsнιη
  • 36,350
Blub
  • 235
Open the Terminal and execute the following command:
dconf write /org/compiz/profiles/unity/plugins/unityshell/show-launcher '"<Alt>space"'
To read the current value, use read option:
dconf read /org/compiz/profiles/unity/plugins/unityshell/show-launcher
If you want to set it to default value, use reset option as following:
dconf reset /org/compiz/profiles/unity/plugins/unityshell/show-launcher
From man dconf:
dconf read KEY
dconf write KEY VALUE
dconf reset [-f] PATH
  • read : Read the value of a key.
  • write: Write a new value to a key.
  • reset: Reset a key or an entire directory. For directories, -f must be specified.
αғsнιη
  • 36,350
You can use CCSM (CompizConfig Settings Manager) to set which shortcut opens the dash or to disable it.
sudo apt-get install compizconfig-settings-manager
Then from the terminal start it by executing ccsm, find the Ubuntu Unity Plugin and select the Launcher tab. Disable the "Key to show Dash..." shortcut.
Jens Erat
  • 5,131
  • 33
  • 37
Balthasar
  • 173
