-1
I want to install Oracle Java (JRE) from the official website.And set it as default.
Dan
  • 3,418
You can install Java by adding the Oracle Java (JDK) 6 / 7 / 8 Installer PPA to your systems software sources.To add the PPA and install Oracle Java 8 open a terminal window (press Ctrl+Alt+T) and copy+paste the following lines:
sudo add-apt-repository ppa:webupd8team/java -y
sudo apt update && sudo apt install oracle-java8-installer -y
When Java is installed you can close the terminal window.
This is the easiest way i know to install java on Ubuntu.
muru
  • 207,228
tinuz
  • 3,962
