When trying to run Sudo-apt-get in terminal in Ubuntu 14.04 it asks for password. I do not remember any password. how to reset password/ solve this problem
Asked
Active
Viewed 91 times
Normally, root user has no password and is locked so that nobody can log into this account. To gain root privileges for system administration, an admin user (member of usergroup sudo) may use the sudo command to run 1 command as root.
So if you did not give root a password for any reason, the password sudo is asking for is your own, the same you need to type for login. You had to chose one when you installed Ubuntu.
If you forgot your OWN user password (maybe because you use automatic login), you have to reset it following the advice of Sachin Kamath above. (Copy of his link)
Byte Commander
- 110,243
