It's been a while since I have been here. I have been very preoccupied with trying to sort out endless problems with my devices getting hacked. I have a bridge set up on my home network. It is a TP-Link 841N, and I had wds enabled, connected as a client on my network. Nmap tells me that port 22 is open, and I have tried to reflash the firmware several times, downloading it through many different proxies, including two openvpn servers, my cellular connection, and the tor network. I also recently had to have my vps provider pgp me a new password because the openvz web panel kept getting hacked. This happened 3 or 4 times, and my provider had to reset the password. So, I scanned my computer for rootkits with both chkroot and rkhunter, and got quite a few warnings. I will post the output here: (Edited for formatting, 1/19/15)
     ##Chrkrootkit output:##
        root@linuxpc:~# chkrootkit
        ROOTDIR is `/'
        Searching for suspicious files and dirs, it may take a while... The following suspicious files and directories were found:
        /usr/lib/debug/.build-id /usr/lib/python2.7/dist-packages/PyQt4/uic/widget-plugins/.noinit
     /usr/lib/pymodules/python2.7/.path /usr/lib/jvm/.java-1.7.0-openjdk amd64.jinfo
        Searching for Suckit rootkit...     Warning: /sbin/init INFECTED
    Checking `sniffer'...      lo: not promisc and no packet sniffer sockets
        wlan0:          PACKET SNIFFER(/sbin/wpa_supplicant[1850], /sbin/dhclient[3145])
    Checking `wted'...  1 deletion(s) between Sat Jan 17 21:43:47 2015 and Sat Jan 17 21:48:36 2015
        Checking `chkutmp'...   The tty of the following user process(es) were not found in /var/run/utmp !
        ! RUID          PID TTY    CMD
        ! root         1463 tty7   /usr/bin/X :0 -background none -verbose -auth /var/run/gdm/auth-for-gdm-4y3SbT/database -seat seat0 -nolisten tcp vt7
        chkutmp: nothing deleted
        Checking `OSX_RSPLUG'...                                    not infected
        root@linuxpc:~# Searching for Suckit rootkit...         Warning: /sbin/init INFECTED
        Searching: command not found
        #Rkhunter Output##
        anon@linuxpc:~$ cat /var/log/rkhunter.log | grep Warning
    [03:36:46]   /usr/sbin/chroot                                [ Warning ]
    [03:36:46] Warning: The file properties have changed:
    [03:36:47]   /usr/sbin/rsyslogd                              [ Warning ]
    [03:36:47] Warning: The file properties have changed:
    [03:36:48]   /usr/bin/awk                                    [ Warning ]
    [03:36:48] Warning: The file properties have changed:
    [03:36:48]   /usr/bin/basename                               [ Warning ]
    [03:36:49]   /usr/bin/curl                                   [ Warning ]
    [03:36:49] Warning: The file '/usr/bin/curl' exists on the system, but it is not present in the rkhunter.dat file.
    [03:36:49]   /usr/bin/cut                                    [ Warning ]
    [03:36:49] Warning: The file properties have changed:
    [03:36:49]   /usr/bin/dirname                                [ Warning ]
    [03:36:49]   /usr/bin/du                                     [ Warning ]
    [03:36:50]   /usr/bin/env                                    [ Warning ]
    [03:36:50] Warning: The file properties have changed:
    [03:36:50]   /usr/bin/file                                   [ Warning ]
    [03:36:50]   /usr/bin/groups                                 [ Warning ]
    [03:36:50]   /usr/bin/head                                   [ Warning ]
    [03:36:51]   /usr/bin/id                                     [ Warning ]
    [03:36:51] Warning: The file properties have changed:
    [03:36:51]   /usr/bin/ldd                                    [ Warning ]
    [03:36:52]   /usr/bin/logger                                 [ Warning ]
    [03:36:52] Warning: The file properties have changed:
    [03:36:52]   /usr/bin/mail                                   [ Warning ]
    [03:36:52] Warning: The file '/usr/bin/mail' exists on the system, but it is not present in the rkhunter.dat file.
    [03:36:52]   /usr/bin/md5sum                                 [ Warning ]
    [03:36:53]   /usr/bin/runcon                                 [ Warning ]
    [03:36:53] Warning: The file properties have changed:
    [03:36:53]   /usr/bin/sha1sum                                [ Warning ]
    [03:36:54]   /usr/bin/sha224sum                              [ Warning ]
    [03:36:54] Warning: The file properties have changed:
    [03:36:54]   /usr/bin/sha256sum                              [ Warning ]
    [03:36:54]   /usr/bin/sha384sum                              [ Warning ]
    [03:36:54]   /usr/bin/sha512sum                              [ Warning ]
    [03:36:54]   /usr/bin/sort                                   [ Warning ]
    [03:36:55]   /usr/bin/stat                                   [ Warning ]
    [03:36:55] Warning: The file properties have changed:
    [03:36:55]   /usr/bin/tail                                   [ Warning ]
    [03:36:55]   /usr/bin/test                                   [ Warning ]
    [03:36:56]   /usr/bin/touch                                  [ Warning ]
    [03:36:56] Warning: The file properties have changed:
    [03:36:56]   /usr/bin/tr                                     [ Warning ]
    [03:36:56]   /usr/bin/uniq                                   [ Warning ]
    [03:36:56]   /usr/bin/users                                  [ Warning ]
    [03:36:57]   /usr/bin/wc                                     [ Warning ]
    [03:36:57] Warning: The file properties have changed:
    [03:36:57]   /usr/bin/wget                                   [ Warning ]
    [03:36:57]   /usr/bin/whatis                                 [ Warning ]
    [03:36:57]   /usr/bin/whereis                                [ Warning ]
    [03:36:58]   /usr/bin/who                                    [ Warning ]
    [03:36:58] Warning: The file properties have changed:
    [03:36:58]   /usr/bin/whoami                                 [ Warning ]
    [03:36:58]   /usr/bin/unhide.rb                              [ Warning ]
    [03:36:58] Warning: The command '/usr/bin/unhide.rb' has been replaced by a script: /usr/bin/unhide.rb: Ruby script, ASCII text
    [03:36:58]   /usr/bin/gawk                                   [ Warning ]
    [03:36:58] Warning: The file '/usr/bin/gawk' exists on the system, but it is not present in the rkhunter.dat file.
    [03:36:58]   /usr/bin/bsd-mailx                              [ Warning ]
    [03:36:58] Warning: The file '/usr/bin/bsd-mailx' exists on the system, but it is not present in the rkhunter.dat file.
    [03:36:59]   /sbin/fsck                                      [ Warning ]
    [03:36:59] Warning: The file properties have changed:
    [03:36:59]   /sbin/ifconfig                                  [ Warning ]
    [03:37:00]   /sbin/route                                     [ Warning ]
    [03:37:00] Warning: The file properties have changed:
    [03:37:01]   /bin/bash                                       [ Warning ]
    [03:37:01] Warning: The file properties have changed:
    [03:37:02]   /bin/cat                                        [ Warning ]
    [03:37:02] Warning: The file properties have changed:
    [03:37:02]   /bin/chmod                                      [ Warning ]
    [03:37:02]   /bin/chown                                      [ Warning ]
    [03:37:02]   /bin/cp                                         [ Warning ]
    [03:37:03]   /bin/date                                       [ Warning ]
    [03:37:03] Warning: The file properties have changed:
    [03:37:03]   /bin/df                                         [ Warning ]
    [03:37:03]   /bin/dmesg                                      [ Warning ]
    [03:37:03]   /bin/echo                                       [ Warning ]
    [03:37:04]   /bin/ls                                         [ Warning ]
    [03:37:04] Warning: The file properties have changed:
    [03:37:05]   /bin/mktemp                                     [ Warning ]
    [03:37:05] Warning: The file properties have changed:
    [03:37:05]   /bin/more                                       [ Warning ]
    [03:37:05]   /bin/mount                                      [ Warning ]
    [03:37:05]   /bin/mv                                         [ Warning ]
    [03:37:06]   /bin/netstat                                    [ Warning ]
    [03:37:06] Warning: The file properties have changed:
    [03:37:06]   /bin/pwd                                        [ Warning ]
    [03:37:06]   /bin/readlink                                   [ Warning ]
    [03:37:07]   /bin/touch                                      [ Warning ]
    [03:37:07] Warning: The file properties have changed:
    [03:37:07]   /bin/uname                                      [ Warning ]
    [03:37:08]   /usr/bin/mawk                                   [ Warning ]
    [03:37:08] Warning: The file '/usr/bin/mawk' does not exist on the system, but it is present in the rkhunter.dat file.
    [03:46:29]   Checking /dev for suspicious file types         [ Warning ]
    [03:46:29] Warning: Suspicious file types found in /dev:
    [03:46:29]   Checking for hidden files and directories       [ Warning ]
    [03:46:29] Warning: Hidden directory found: '/etc/.java: directory '
    [03:46:29] Warning: Hidden directory found: '/dev/.udev: directory '
    [03:46:29] Warning: Hidden file found: /dev/.initramfs: symbolic link to `/run/initramfs'
## End Output##
I don't think it was too long ago that I ran a propupdate, and rkhunter sure is giving me a lot of warnings. The promiscious interface warning was not showing up earlier. Can someone with more expertise please help me decipher these results? I know the suckit rootkit can be a false positive, but Rkhunters is making me nervous, along with all the strange activity I've dealt with on my vps, which was also a tor exit node for a long time. Thanks.
(Update 1/19/15) I took your advice and removed the lines stating nothing was infected, and upgraded rkhunter. I then ran the new version (1.4.2) and these warnings popped up:
[15:48:20]   /usr/local/bin/rkhunter                         [ Warning ]
[15:48:20] Warning: The file '/usr/local/bin/rkhunter' exists on the system, but it is not present in the 'rkhunter.dat' file.
[15:48:20]   /usr/sbin/adduser                               [ Warning ]
[15:48:20] Warning: The command '/usr/sbin/adduser' has been replaced by a script: /usr/sbin/adduser: Perl script, ASCII text executable
[15:48:20]   /usr/sbin/chroot                                [ Warning ]
[15:48:20] Warning: The file properties have changed:
[15:48:22]   /usr/sbin/rsyslogd                              [ Warning ]
[15:48:22] Warning: The file properties have changed:
[15:48:23]   /usr/bin/awk                                    [ Warning ]
[15:48:23] Warning: The file properties have changed:
[15:48:23] Warning: No symbolic link target found for file '/usr/bin/awk' in the 'rkhunter.dat' file.
[15:48:23]   /usr/bin/basename                               [ Warning ]
[15:48:24]   /usr/bin/curl                                   [ Warning ]
[15:48:24] Warning: The file '/usr/bin/curl' exists on the system, but it is not present in the 'rkhunter.dat' file.
[15:48:24]   /usr/bin/cut                                    [ Warning ]
[15:48:24] Warning: The file properties have changed:
[15:48:24]   /usr/bin/dirname                                [ Warning ]
[15:48:25]   /usr/bin/du                                     [ Warning ]
[15:48:25] Warning: The file properties have changed:
[15:48:25]   /usr/bin/env                                    [ Warning ]
[15:48:25]   /usr/bin/file                                   [ Warning ]
[15:48:25]   /usr/bin/GET                                    [ Warning ]
[15:48:25] Warning: No symbolic link target found for file '/usr/bin/GET' in the 'rkhunter.dat' file.
[15:48:26]   /usr/bin/groups                                 [ Warning ]
[15:48:26] Warning: The file properties have changed:
[15:48:26]   /usr/bin/head                                   [ Warning ]
[15:48:26]   /usr/bin/id                                     [ Warning ]
[15:48:27]   /usr/bin/ldd                                    [ Warning ]
[15:48:27] Warning: The file properties have changed:
[15:48:27] Warning: The command '/usr/bin/ldd' has been replaced by a script: /usr/bin/ldd: Bourne-Again shell script, ASCII text executable
[15:48:27]   /usr/bin/less                                   [ Warning ]
[15:48:27] Warning: No symbolic link target found for file '/usr/bin/less' in the 'rkhunter.dat' file.
[15:48:27]   /usr/bin/locate                                 [ Warning ]
[15:48:27] Warning: No symbolic link target found for file '/usr/bin/locate' in the 'rkhunter.dat' file.
[15:48:27]   /usr/bin/logger                                 [ Warning ]
[15:48:28]   /usr/bin/mail                                   [ Warning ]
[15:48:28] Warning: The file '/usr/bin/mail' exists on the system, but it is not present in the 'rkhunter.dat' file.
[15:48:28]   /usr/bin/md5sum                                 [ Warning ]
[15:48:28] Warning: The file properties have changed:
[15:48:29]   /usr/bin/pkill                                  [ Warning ]
[15:48:29] Warning: No symbolic link target found for file '/usr/bin/pkill' in the 'rkhunter.dat' file.
[15:48:29]   /usr/bin/runcon                                 [ Warning ]
[15:48:29] Warning: The file properties have changed:
[15:48:29]   /usr/bin/sha1sum                                [ Warning ]
[15:48:30]   /usr/bin/sha224sum                              [ Warning ]
[15:48:30] Warning: The file properties have changed:
[15:48:30]   /usr/bin/sha256sum                              [ Warning ]
[15:48:30]   /usr/bin/sha384sum                              [ Warning ]
[15:48:30]   /usr/bin/sha512sum                              [ Warning ]
[15:48:31]   /usr/bin/sort                                   [ Warning ]
[15:48:31] Warning: The file properties have changed:
[15:48:31]   /usr/bin/ssh                                    [ Warning ]
[15:48:31] Warning: The file '/usr/bin/ssh' exists on the system, but it is not present in the 'rkhunter.dat' file.
[15:48:31]   /usr/bin/stat                                   [ Warning ]
[15:48:32]   /usr/bin/tail                                   [ Warning ]
[15:48:32] Warning: The file properties have changed:
[15:48:32]   /usr/bin/telnet                                 [ Warning ]
[15:48:32] Warning: The file '/usr/bin/telnet' exists on the system, but it is not present in the 'rkhunter.dat' file.
[15:48:32]   /usr/bin/test                                   [ Warning ]
[15:48:32]   /usr/bin/touch                                  [ Warning ]
[15:48:33] Warning: No symbolic link target found for file '/usr/bin/touch' in the 'rkhunter.dat' file.
[15:48:33]   /usr/bin/tr                                     [ Warning ]
[15:48:33] Warning: The file properties have changed:
[15:48:33]   /usr/bin/uniq                                   [ Warning ]
[15:48:33]   /usr/bin/users                                  [ Warning ]
[15:48:34]   /usr/bin/w                                      [ Warning ]
[15:48:34] Warning: No symbolic link target found for file '/usr/bin/w' in the 'rkhunter.dat' file.
[15:48:34]   /usr/bin/wc                                     [ Warning ]
[15:48:34] Warning: The file properties have changed:
[15:48:34]   /usr/bin/wget                                   [ Warning ]
[15:48:34]   /usr/bin/whatis                                 [ Warning ]
[15:48:34]   /usr/bin/whereis                                [ Warning ]
[15:48:35]   /usr/bin/which                                  [ Warning ]
[15:48:35] Warning: No symbolic link target found for file '/usr/bin/which' in the 'rkhunter.dat' file.
[15:48:35]   /usr/bin/who                                    [ Warning ]
[15:48:35] Warning: The file properties have changed:
[15:48:35]   /usr/bin/whoami                                 [ Warning ]
[15:48:35]   /usr/bin/gawk                                   [ Warning ]
[15:48:35] Warning: The file '/usr/bin/gawk' exists on the system, but it is not present in the 'rkhunter.dat' file.
[15:48:35]   /usr/bin/lwp-request                            [ Warning ]
[15:48:35] Warning: The command '/usr/bin/lwp-request' has been replaced by a script: /usr/bin/lwp-request: Perl script, ASCII text executable
[15:48:35]   /usr/bin/bsd-mailx                              [ Warning ]
[15:48:35] Warning: The file '/usr/bin/bsd-mailx' exists on the system, but it is not present in the 'rkhunter.dat' file.
[15:48:35]   /usr/bin/telnet.netkit                          [ Warning ]
[15:48:36] Warning: The file '/usr/bin/telnet.netkit' exists on the system, but it is not present in the 'rkhunter.dat' file.
[15:48:36]   /sbin/depmod                                    [ Warning ]
[15:48:36] Warning: No symbolic link target found for file '/sbin/depmod' in the 'rkhunter.dat' file.
[15:48:36]   /sbin/fsck                                      [ Warning ]
[15:48:36] Warning: The file properties have changed:
[15:48:36]   /sbin/ifconfig                                  [ Warning ]
[15:48:37]   /sbin/ifdown                                    [ Warning ]
[15:48:37] Warning: No symbolic link target found for file '/sbin/ifdown' in the 'rkhunter.dat' file.
[15:48:37]   /sbin/insmod                                    [ Warning ]
[15:48:37] Warning: No symbolic link target found for file '/sbin/insmod' in the 'rkhunter.dat' file.
[15:48:37]   /sbin/ip                                        [ Warning ]
[15:48:37] Warning: No symbolic link target found for file '/sbin/ip' in the 'rkhunter.dat' file.
[15:48:37]   /sbin/lsmod                                     [ Warning ]
[15:48:37] Warning: No symbolic link target found for file '/sbin/lsmod' in the 'rkhunter.dat' file.
[15:48:38]   /sbin/modinfo                                   [ Warning ]
[15:48:38] Warning: No symbolic link target found for file '/sbin/modinfo' in the 'rkhunter.dat' file.
[15:48:38]   /sbin/modprobe                                  [ Warning ]
[15:48:38] Warning: No symbolic link target found for file '/sbin/modprobe' in the 'rkhunter.dat' file.
[15:48:38]   /sbin/rmmod                                     [ Warning ]
[15:48:38] Warning: No symbolic link target found for file '/sbin/rmmod' in the 'rkhunter.dat' file.
[15:48:38]   /sbin/route                                     [ Warning ]
[15:48:38] Warning: The file properties have changed:
[15:48:39]   /bin/bash                                       [ Warning ]
[15:48:39] Warning: The file properties have changed:
[15:48:39]   /bin/cat                                        [ Warning ]
[15:48:40]   /bin/chmod                                      [ Warning ]
[15:48:40] Warning: The file properties have changed:
[15:48:40]   /bin/chown                                      [ Warning ]
[15:48:40]   /bin/cp                                         [ Warning ]
[15:48:40]   /bin/date                                       [ Warning ]
[15:48:41]   /bin/df                                         [ Warning ]
[15:48:41] Warning: The file properties have changed:
[15:48:41]   /bin/dmesg                                      [ Warning ]
[15:48:41]   /bin/echo                                       [ Warning ]
[15:48:43]   /bin/ls                                         [ Warning ]
[15:48:43] Warning: The file properties have changed:
[15:48:43]   /bin/lsmod                                      [ Warning ]
[15:48:43] Warning: No symbolic link target found for file '/bin/lsmod' in the 'rkhunter.dat' file.
[15:48:43]   /bin/mktemp                                     [ Warning ]
[15:48:43]   /bin/more                                       [ Warning ]
[15:48:43]   /bin/mount                                      [ Warning ]
[15:48:44]   /bin/mv                                         [ Warning ]
[15:48:44] Warning: The file properties have changed:
[15:48:44]   /bin/netstat                                    [ Warning ]
[15:48:44]   /bin/pwd                                        [ Warning ]
[15:48:45]   /bin/readlink                                   [ Warning ]
[15:48:45] Warning: The file properties have changed:
[15:48:45]   /bin/sh                                         [ Warning ]
[15:48:45] Warning: No symbolic link target found for file '/bin/sh' in the 'rkhunter.dat' file.
[15:48:45]   /bin/touch                                      [ Warning ]
[15:48:46]   /bin/uname                                      [ Warning ]
[15:48:46] Warning: The file properties have changed:
[15:48:46]   /bin/which                                      [ Warning ]
[15:48:46] Warning: The command '/bin/which' has been replaced by a script: /bin/which: POSIX shell script, ASCII text executable
[15:48:46]   /etc/rkhunter.conf                              [ Warning ]
[15:48:46] Warning: The file '/etc/rkhunter.conf' exists on the system, but it is not present in the 'rkhunter.dat' file.
[16:08:55]   Checking /dev for suspicious file types         [ Warning ]
[16:08:55] Warning: Suspicious file types found in /dev:
[16:08:55]   Checking for hidden files and directories       [ Warning ]
[16:08:55] Warning: Hidden directory found: /etc/.java: directory
[16:08:55] Warning: Hidden directory found: /dev/.udev: directory
[16:08:55] Warning: Hidden file found: /dev/.blkid.tab: ASCII text
[16:08:55] Warning: Hidden file found: /dev/.blkid.tab.old: ASCII text
[16:08:55] Warning: Hidden file found: /dev/.initramfs: symbolic link to `/run/initramfs'
I can see that some of these warnings are caused by upgrading rkhunter and having old configuration files in /etc, but I am not so sure about the others. Do you still think that things look normal? I sincerely appreciate the help.
Chev_603
  • 1,728
If you use expert tools, also read the expert manual. You have warnings only, no errors... ;-)
Furthermore, rootkits are the most nasty pieces of malware out there and can hide themselves even from rootkit hunters. Read the FAQ because the correct way of doing this is to boot from a live CD on a CD-R or DVD-R (write once!), mount all your hard-disks read-only, install the software on the RAM disk and only then start hunting.
Fabby
  • 35,017
