I recently upgraded my server from Ubuntu 12.04 to 14.10. I had installed GCC 4.9 (4.9.2 apparently) before the upgrade and today I wanted to install gcc-4.9-multilib, but apt-get gave me:
gcc-4.9-multilib : Depends: gcc-4.9 (= 4.9.1-16ubuntu6) but 4.9.2-0ubuntu1~12.04 is to be installed
So I removed gcc-4.9 and wanted to reinstall it, but the same game happens with gcc-4.9-base:
gcc-4.9 : Depends: cpp-4.9 (= 4.9.1-16ubuntu6) but 4.9.2-0ubuntu1~12.04 is to be installed
Depends: gcc-4.9-base (= 4.9.1-16ubuntu6) but 4.9.2-0ubuntu1~12.04 is to be installed
cpp-4.9 I could remove, but removing gcc-4.9-base would leave not much more than the kernel behind I guess...
I also tried using aptitude to remove 4.9.2-0ubuntu1~12.04 and installing 4.9.1-16ubuntu6, but when I try to apply the selected changes, it gives me:
Some packages were broken and have been fixed:
Keep the following packages at their current version:
gcc-4.9-base [4.9.2-0ubuntu1~12.04 (now)]
So how do I get rid of that 12.04 stuff without removing my entire operating system?
Edit:
My sources:
bash$ cat /etc/apt/sources.list /etc/apt/sources.list.d/*.list
deb http://archive.ubuntu.com/ubuntu utopic main
deb http://archive.ubuntu.com/ubuntu utopic-updates main
deb http://security.ubuntu.com/ubuntu utopic-security main universe restricted
deb http://archive.ubuntu.com/ubuntu utopic universe restricted
deb http://archive.ubuntu.com/ubuntu utopic-updates universe restricted
deb http://pkg.jenkins-ci.org/debian binary/
# deb http://ppa.launchpad.net/ubuntu-toolchain-r/test/ubuntu utopic main
# deb-src http://ppa.launchpad.net/ubuntu-toolchain-r/test/ubuntu utopic main
Trying to fix anything broken:
bash$ sudo apt-get -f install
Reading package lists... Done
Building dependency tree
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Policy info:
bash$ apt-cache policy gcc-4.9
gcc-4.9:
Installed: (none)
Candidate: 4.9.1-16ubuntu6
Version table:
4.9.1-16ubuntu6 0
500 http://archive.ubuntu.com/ubuntu/ utopic/main amd64 Packages
Trying to install gcc-4.9:
bash$ sudo apt-get install gcc-4.9
gcc-4.9 : Depends: cpp-4.9 (= 4.9.1-16ubuntu6) but it is not going to be installed
Trying to install gcc-4.9-base=4.9.1-16ubuntu6:
Trying to upgrade Ubuntu:
bash$ sudo do-release-upgrade
Checking for a new Ubuntu release
No new release found
And I'm not on LTS:
bash$ cat /etc/update-manager/release-upgrades
# Default behavior for the release upgrader.
[DEFAULT]
# Default prompting behavior, valid options:
# never - Never check for a new release.
# normal - Check to see if a new release is available. If more than one new
# release is found, the release upgrader will attempt to upgrade to
# the release that immediately succeeds the currently-running
# release.
# lts - Check to see if a new LTS release is available. The upgrader
# will attempt to upgrade to the first LTS release available after
# the currently-running one. Note that this option should not be
# used if the currently-running release is not itself an LTS
# release, since in that case the upgrader won't be able to
# determine if a newer release is available.
Prompt=normal
Update:
bash$ sudo apt-get update
Ign http://archive.ubuntu.com utopic InRelease
Ign http://security.ubuntu.com utopic-security InRelease
Ign http://archive.ubuntu.com utopic-updates InRelease
Get:1 http://security.ubuntu.com utopic-security Release.gpg [933 B]
Hit http://archive.ubuntu.com utopic Release.gpg
Get:2 http://security.ubuntu.com utopic-security Release [62.0 kB]
Get:3 http://archive.ubuntu.com utopic-updates Release.gpg [933 B]
Ign http://pkg.jenkins-ci.org binary/ InRelease
Get:4 http://archive.ubuntu.com utopic-updates Release [62.0 kB]
Get:5 http://security.ubuntu.com utopic-security/main amd64 Packages [110 kB]
Hit http://pkg.jenkins-ci.org binary/ Release.gpg
Get:6 http://security.ubuntu.com utopic-security/universe amd64 Packages [46.6 kB]
Get:7 http://security.ubuntu.com utopic-security/restricted amd64 Packages [8,496 B]
Hit http://archive.ubuntu.com utopic/main amd64 Packages
Get:8 http://security.ubuntu.com utopic-security/main i386 Packages [109 kB]
Hit http://pkg.jenkins-ci.org binary/ Packages
Hit http://archive.ubuntu.com utopic/universe amd64 Packages
Get:9 http://security.ubuntu.com utopic-security/universe i386 Packages [46.5 kB]
Hit http://archive.ubuntu.com utopic/restricted amd64 Packages
Get:10 http://security.ubuntu.com utopic-security/restricted i386 Packages [8,438 B]
Hit http://archive.ubuntu.com utopic/main i386 Packages
Get:11 http://security.ubuntu.com utopic-security/main Translation-en [52.8 kB]
Hit http://archive.ubuntu.com utopic/universe i386 Packages
Hit http://security.ubuntu.com utopic-security/restricted Translation-en
Hit http://archive.ubuntu.com utopic/restricted i386 Packages
Hit http://archive.ubuntu.com utopic/main Translation-en
Get:12 http://security.ubuntu.com utopic-security/universe Translation-en [25.7 kB]
Hit http://archive.ubuntu.com utopic/main Translation-en_GB
Hit http://archive.ubuntu.com utopic/restricted Translation-en
Hit http://archive.ubuntu.com utopic/restricted Translation-en_GB
Hit http://archive.ubuntu.com utopic/universe Translation-en
Hit http://archive.ubuntu.com utopic/universe Translation-en_GB
Get:13 http://archive.ubuntu.com utopic-updates/main amd64 Packages [162 kB]
Get:14 http://archive.ubuntu.com utopic-updates/universe amd64 Packages [63.3 kB]
Get:15 http://archive.ubuntu.com utopic-updates/restricted amd64 Packages [8,496 B]
Get:16 http://archive.ubuntu.com utopic-updates/main i386 Packages [160 kB]
Ign http://pkg.jenkins-ci.org binary/ Translation-en_US
Get:17 http://archive.ubuntu.com utopic-updates/universe i386 Packages [63.2 kB]
Ign http://pkg.jenkins-ci.org binary/ Translation-en_GB
Get:18 http://archive.ubuntu.com utopic-updates/restricted i386 Packages [8,438 B]
Get:19 http://archive.ubuntu.com utopic-updates/main Translation-en [74.2 kB]
Hit http://archive.ubuntu.com utopic-updates/restricted Translation-en
Get:20 http://archive.ubuntu.com utopic-updates/universe Translation-en [35.2 kB]
Fetched 1,108 kB in 5s (216 kB/s)
Upgrade:
bash$ sudo apt-get upgrade
Calculating upgrade... Done
Dist-upgrade:
bash$ sudo apt-get dist-upgrade
And something I stumbled across:
bash$ apt list -a gcc-4.9-base
Listing... Done
gcc-4.9-base/now 4.9.2-0ubuntu1~12.04 amd64 [installed,local]
gcc-4.9-base/utopic 4.9.1-16ubuntu6 amd64
