I have Ubuntu 14.04 and I have tried to install Teamviewer by the command line (it says I need superuser privileges) and I have tried the graphical installer but it says it cannot install.
Update
I have got Superuser privileges but it says
dpkg: error processing archive teamviewer_linux.deb (--install):
cannot access archive: No such file or directory
Errors were encountered while processing: teamviewer_linux.deb
heemayl
  • 93,925
to get superuser privileges,
first execute in a terminal
sudo passwd root
you will prompted for a new Unix password. Write it twice(second for confirmation).
Then execute
sudo passwd -u root
to unlock the account. This should return
passwd: password expiry information changed
then execute,
su
and enter in password. you should be in super user privilege mode, then retry your install.
Reverting back
If you want to disable root account in Ubuntu you need to lock the root account by using the following command
sudo passwd -l root
