By default /etc/pam.d/common-auth looks like this
$ cat /etc/pam.d/common-auth
# /etc/pam.d/common-auth - authentication settings common to all services
# This file is included from other service-specific PAM config files,
# and should contain a list of the authentication modules that define
# the central authentication scheme for use on the system
# (e.g., /etc/shadow, LDAP, Kerberos, etc.).  The default is to use the
# traditional Unix authentication mechanisms.
# As of pam 1.0.1-6, this file is managed by pam-auth-update by default.
# To take advantage of this, it is recommended that you configure any
# local modules either before or after the default block, and use
# pam-auth-update to manage selection of other modules.  See
# pam-auth-update(8) for details.
# here are the per-package modules (the "Primary" block)
auth    [success=1 default=ignore]  pam_unix.so nullok_secure
# here's the fallback if no module succeeds
auth    requisite           pam_deny.so
# prime the stack with a positive return value if there isn't one already;
# this avoids us returning an error just because nothing sets a success code
# since the modules above will each just jump around
auth    required            pam_permit.so
# and here are more per-package modules (the "Additional" block)
auth    optional            pam_cap.so
# end of pam-auth-update config
I have successfully been modifying the above file appending auth required pam_exec.so expose_authtok /path/to/some/script
I'm reviewing whether the above is the recommended way of modifying PAM or if I should be creating a PAM-config in /usr/share/pam-configs/my-custom-thing.
Is creating a PAM-config the proper way to make my required change to PAM?
hydrajump
  • 191
