Error mounting /dev/sda4 at /media/danny/70D49480D4944A6C: Command-line `mount -t "ntfs" -o "uhelper=udisks2,nodev,nosuid,uid=1000,gid=1000,dmask=0077,fmask=0177" "/dev/sda4" "/media/danny/70D49480D4944A6C"' exited with non-zero exit status 14: The disk contains an unclean file system (0, 0).
Metadata kept in Windows cache, refused to mount.
Failed to mount '/dev/sda4': Operation not permitted
The NTFS partition is in an unsafe state. Please resume and shutdown
Windows fully (no hibernation or fast restarting), or mount the volume
read-only with the 'ro' mount option.
thats what it said, can someone help me?
jasmines
  • 11,311
I assume you have Windows (maybe 8?) installed on your 4th partition (which is /dev/sda4 to Linux). Windows uses hibernation to fasten up its boot, but therefore stores RAM data and other stuff to its partition on the hard disk. This leads to your errors as Ubuntu can not properly access the drive due to Windows' lock. Boot into WIndows and disable the auto-hibernation feature and shut it down completely. Then you should be able to access the volume with Ubuntu. Greetings!
Byte Commander
  • 110,243
You can still mount the drive read only to access your data.
Create a mountpoint
sudo mkdir media/danny/drive
and then mount it as read only
sudo mount -o /dev/sda4/ media/danny/drive
