When I try to use tab completion with rake, only files are suggested:
$ rails test-app | grep -v create; cd test-app
$ rake <TAB><TAB>
app/ db/ lib/ public/ README test/ vendor/
config/ doc/ log/ Rakefile script/ tmp/
The package rake-0.8.7-2 includes a Bash completion configuration file,
$ debsums -e rake
/etc/bash_completion.d/rake OK
so I expect that pressing tab should suggest the tasks available to rake:
$ rake --tasks
(in ~/sandbox/test-app)
rake db:abort_if_pending_migrations # Raises an error if there are pending migrations
rake db:charset # Retrieves the charset for the current environment's database
rake db:collation # Retrieves the collation for the current environment's database
rake db:create # Create the database defined in config/database.yml for the current RAIL...
rake db:create:all # Create all the local databases defined in config/database.yml
rake db:drop # Drops the database for the current RAILS_ENV
What am I doing wrong?
The problem persists after reinstalling rake and restarting my computer. My ~/.bashrc contains:
if [ -f /etc/bash_completion ] && ! shopt -oq posix; then
. /etc/bash_completion
fi
but completion for rake doesn't appear to be registered:
$ complete | grep rake
Explicitly running . /etc/bash_completion in the shell doesn't solve the problem, but running the following command does enable completion for rake temporarily:
$ grep complete /etc/bash_completion.d/rake
[ -n "${have:-}" ] && complete -F _rake $filenames rake
$ complete -F _rake rake
$ rake <TAB><TAB>
db:abort_if_pending_migrations db:version rails:update
db:charset doc:app rails:update:application_controller
db:collation doc:clobber_app rails:update:configs
db:create doc:clobber_plugins rails:update:generate_dispatchers
db:create:all doc:clobber_rails rails:update:javascripts
db:drop doc:guides rails:update:scripts
