How do I delete all Folders with a specific name (e.g. 128Kbps_Songs) without deleting its files
For example if I have directory "MP3_SONGS" with subdirectories "A", "B", "C" and each subdirectory has MANY directory Contains Film Name "FILM_NAME1", "FILM_NAME2", "FILM_NAME3" in it, In That Each Film NAme I have specific Folder NAme (128Kbps_Songs) in this "128Kbps_Songs" Folder I have That Film mp3 Songs Files
how can I remove the Folder "128Kbps_Songs", in Each Film_Name directory and Have to get these mp3 songs in that FILM_NAME.. ( Have to Delete 128Kbps_Songs Folder in all FILM_NAME without deleting the mp3 Songs in it, have to get the mp3 in FILM_NAME Directory..
MP3_SONGS (Parent Directory) ------ A , B, C
A (Sub Directory1) ------ FILM_NAME1 , FILM_NAME2
B (Sub Directory2) ------ FILM_NAME3 , FILM_NAME4
c (Sub Directory3) ------ FILM_NAME5 , FILM_NAME6
FILM_NAME1 (Directory) ---- 128Kbps_Songs (Directory) ------ FILM_NAME1 (MP3 Files)
FILM_NAME2 (Directory) ---- 128Kbps_Songs (Directory) ------ FILM_NAME2 (MP3 Files)
FILM_NAME3 (Directory) ---- 128Kbps_Songs (Directory) ------ FILM_NAME3 (MP3 Files)
FILM_NAME4 (Directory) ---- 128Kbps_Songs (Directory) ------ FILM_NAME4 (MP3 Files)
FILM_NAME5 (Directory) ---- 128Kbps_Songs (Directory) ------ FILM_NAME5 (MP3 Files)
FILM_NAME6 (Directory) ---- 128Kbps_Songs (Directory) ------ FILM_NAME6 (MP3 Files)
Need Files in:
FILM_NAME1 (Directory)  ------ FILM_NAME1 (MP3 Files)
FILM_NAME2 (Directory)  ------ FILM_NAME2 (MP3 Files)
FILM_NAME3 (Directory)  ------ FILM_NAME3 (MP3 Files)
FILM_NAME4 (Directory)  ------ FILM_NAME4 (MP3 Files)
FILM_NAME5 (Directory)  ------ FILM_NAME5 (MP3 Files)
FILM_NAME6 (Directory)  ------ FILM_NAME6 (MP3 Files)
αғsнιη
  • 36,350
Chatcafe
First move all MP3 files up one level by the command as following:
find MP3_SONGS -type f -name '*.mp3' -execdir echo mv -v '{}' .. \;
  • The -type f option looks for all files
  • The -name '*.mp3' filter files which end with .mp3
  • The command mv -v '{}' .. will be run for each subdirectory containing the matched file, which is not normally the directory in which you started find (action of the -execdir).
  • The string '{}' specifies the current file name being processed everywhere it occurs in the arguments to the command.
Note: After running above command, remove the echo command to perform running actual mv command.
Then try to delete all empty directories (128Kbps_Songs directories):
find MP3_SONGS -empty -type d -name '128Kbps_Songs' -delete
  • The -empty : File is empty and is either a regular file or a directory.
  • The -type d option as the same as -type f but this looks for all directories instead.
  • The -delete, deletes the found file or directory.
See man find for more info.
αғsнιη
  • 36,350
Create a simple script with following contents
#!/bin/bash
while IFS= read -r -d '' n;
do
   dir=$(dirname "$n") ;
   mv "${n}"/* "${dir}"
   rmdir "${n}"
done < <(find -type d -name "128Kbps_Songs" -print0)
Save it and make it executable using chmod +x your_script
Now run it using ./your_script
Here IFS= is done to preserve the space in the filename or path.
  • -r - disables interpretion of backslash escapes and line-continuation in the read data.
  • -d - recognize delimiter as data-end. Here it is emptying out the IFS
  • dirname is use to remove the last folder name i.e 128Kbps_Songs from the find command output. (from ./temp/MP3_SONGS/128Kbps_Songs to ./temp/MP3_SONGS)
g_p
  • 19,034
  • 59
  • 69
