So, here is a question:
How to deploy Mezzanine, a Django CMS, locally with MySQL instead of default SQLite?
What is the exact recipe?
sdd
  • 217
Script in one piece is in ->here
1. Python
Python is preinstalled in Ubuntu and AFAIK it's vital to some system/desktop-env operations, but just in case:
sudo apt-get install python
sudo apt-get install python-pip
sudo apt-get install build-essential python-dev
2. MySQL
You need to install (a)server, (b)client, (c)dev libs & headers, (d)python adapter
sudo apt-get install mysql-server
sudo apt-get install mysql-client-5.5
sudo apt-get install libmysqlclient-dev
sudo apt-get install python-mysqldb
3. Credentials
Establish MySQL credentials, tutorial on this is ->here, so that you have the following users with corresponding login commands:
  • root user
    mysql -u root -p / password
  • Mezzanine user
    mysql -u mezz -p / masterkey
4. Install Mezzanine
pip install mezzanine
5. Create Project
mezzanine-project myproject
cd myproject
6. Configure db to MySQL
Use your credentials from step 3.
vim local_settings.py
That's a Python file. DATABASES variable should be made to be like this (use your credentials at italicized places):
DATABASES = {
    "default": {
        # Ends with "postgresql_psycopg2", "mysql", "sqlite3" or "oracle".
        "ENGINE": "django.db.backends.mysql",
        # DB name or path to database file if using sqlite3.
        "NAME": "myproject",
        # Not used with sqlite3.
        "USER": "mezz",
        "PASSWORD": "masterkey",
        # Set to empty string for localhost. Not used with sqlite3.
        "HOST": "",
        # Set to empty string for default. Not used with sqlite3.
        "PORT": "",
7. Do Mezzanine routines
Collect static files and templates
python manage.py collectstatic
python manage.py collecttemplates
Synchronize with database. This step depends on the Django version, at the time of writing this, Django 1.7 is still not supported, so use syncdb:
python manage.py syncdb
You may also consifer using South migration manager, but know that South project is at it's dusk since Django 1.7 has new migration system.
After syncdb output you'd have a superuser (for entering Mezzanine's admin section). You can create superuser separately after sync:
python manage.py createsuperuser
Run built-in server of Mezzanine (more concretely, it's Django's lightweight server):
python manage.py runserver
8. Go
Point your browser at http://127.0.0.1:8000 and hopefully you'll see the Mezzanine standard greeting.
9. Production Deployment
->Here is a good guide, you can use it to create a demo site in production environment (on that particular site it's free with some limits). And here are their settings for MySQL.
10. Extras
11. 'Revisions'
Some revisions I gathered on my way:
  • South migration manager needs some change in Database section of your settings.py
  • Mezzanine and versioning seemed very frustrating to me: it doesn't support django 1.7, and on my hosting provider there was no root access, so I should have installed MySQL-Python ('adapter') through pip. Some versions of adapter-mezzanine-django are incompatible.
For now, I use Mezzanine v3.1.10, Django v1.6.10 and MySQL-Python v1.2.3 and it works. I disabled South backend addon, because it made things for my deployment more complex rather than simpler.
12. Postscript
If someone advises me about how to improve this guide, I will do it. j-D
0xF2
  • 3,155
sdd
  • 217
