I use Ubuntu 12.04 (I have not upgraded to 14.04 for performance reasons) but I don't like Unity. How can I install XFCE as my default graphic system, and completely remove Unity?
Jos
  • 30,529
  • 89
  • 96
wwwjsw
  • 165
You can install the entire xfce ubuntu package using the following commands:
sudo apt-get update
sudo apt-get install xfce4
Alternatively, you can install the entire xubuntu package:
sudo apt-get install xubuntu-desktop
To uninstall unity:
sudo apt-get purge ubuntu-desktop unity-*
mchid
  • 44,904
  • 102
  • 162
Test this:
Switch on your computer.
Press and hold the Shift key, which will bring up the Grub menu.
In the Grub menu select the line which starts with ---- Advanced options.
Select the line ending with ---- (recovery mode) something like:
Ubuntu GNU/Linux, with Linux 3.2.0-26-generic (recovery mode)
Press Enter key and your machine will begin the boot process.
Your pc should display a menu with a number of options.
Select the line will be ---- Drop to root shell prompt, press enter with this option highlighted.
In the terminal run it:
mount -o remount, rw /
mount --all
apt-get update
apt-get install --reinstall aptitude deborphan
aptitude remove '?and(?reverse-depends(gnome),?not(?reverse-depends(?exact-name(xubuntu-desktop))))'
aptitude remove '?and(?reverse-depends(ubuntu),?not(?reverse-depends(?exact-name(xubuntu-desktop))))'
apt-get install --reinstall xubuntu-desktop
apt-get dist-upgrade
deborphan
apt-get --purge remove $(deborphan)
deborphan --libdevel
apt-get --purge remove $(deborphan --libdevel)
deborphan --find-config
dpkg --purge $(deborphan --find-config)
apt-get autoremove
apt-get clean
reboot
kyodake
  • 17,808
