Tried all combinations for create mask and force create mode. Regardless of this, all created files got "rw-r--r--" instead of "rw-rw-???" (I don't care about "others" permissions).
smbd version 4.1.6-ubuntu (latest one from 14.04)
Here's excerpt from smb.conf
[global]
    workgroup = MYDOMAIN
    realm = MYDOMAIN.FQDN
    server string = Файловый сервер %h (%i:%a)
    security = ADS
    allow trusted domains = No
    map to guest = Bad User
    obey pam restrictions = Yes
    pam password change = Yes
    passwd program = /usr/bin/passwd %u
    passwd chat = *Enter\snew\s*\spassword:* %n\n *Retype\snew\s*\spassword:* %n\n *password\supdated\ssuccessfully* .
    unix password sync = Yes
    syslog = 0
    log file = /var/log/samba/%U.%m.log
    max log size = 1000
    load printers = No
    printcap name = /dev/null
    disable spoolss = Yes
    dns proxy = No
    usershare allow guests = Yes
    panic action = /usr/share/samba/panic-action %d
    winbind enum users = Yes
    winbind enum groups = Yes
    winbind refresh tickets = Yes
    recycle:keeptree = yes
    idmap config * : range = 10000-50000
    idmap config * : schema_mode = rid
    idmap config MYDOMAIN : default = yes
    idmap config MYDOMAIN : cache time = 180
    idmap config MYDOMAIN : backend = rid
    idmap config MYDOMAIN : range = 100000-500000
    idmap config MYDOMAIN : schema_mode = rid
    idmap config * : backend = rid
    valid users = @MYDOMAIN\\acl_rsk30srv042_valid, @MYDOMAIN\acl_rsk30srv042_sd-rw, MYDOMAIN\svc_scan_330-001, MYDOMAIN\sysop, eao\administrator, MYDOMAIN\svc_sadm_330-02
    admin users = MYDOMAIN\svc_scan_330-001, MYDOMAIN\svc_sadm_330-02
    create mask = 0775
    force create mode = 0770
    directory mask = 0775
    force directory mode = 0770
    map acl inherit = Yes
    map archive = No
    map readonly = no
    store dos attributes = Yes
    vfs objects = recycle, acl_xattr
[homes]
    comment = %S's personal folder
    path = /home/%D/%U
    valid users = @MYDOMAIN\xall-330
    read only = No
    create mask = 0700
    directory mask = 0700
    browseable = No
    volume = %U-%S
    vfs objects = recycle:keeptree=yes
[IPC$]
    path = /etc/samba/fakeIPC
    valid users = "@MYDOMAIN\domain users", @MYDOMAIN\xall-330, @MYDOMAIN\acl_share_330-sov2014, nobody
    guest ok = Yes
[obmen]
    comment = Common file exchange
    path = /var/samba/obmen
    write list = @MYDOMAIN\acl_rsk30srv042_valid
    force group = MYDOMAIN\xall-330
    read only = No
    force create mode = 0666
    force directory mode = 0666
    guest ok = Yes
    browseable = No
    volume = obmen
    vfs objects = extd_audit, recycle:keeptree=yes
[secret]
    comment = Depts' folders
    path = /var/samba/secret
    guest ok = Yes
[053]
    comment = 053 - IT dept
    path = /var/samba/secret/053
    valid users = @MYDOMAIN\acl_share_330-053-rw
    force group = @MYDOMAIN\acl_share_330-053-rw
    read only = No
    guest ok = Yes
    browseable = No
    vfs objects = recycle:keeptree=yes, extd_audit
Folder rights:
drwxrwxr-x   2 root root fakeIPC
drwxrwxrwx   9 nobody MYDOMAIN\xall-330 obmen
dr-xrwxr-x  36 nobody MYDOMAIN\xall-330 secret
drwxrwxrwx 17 nobody MYDOMAIN\acl_share_330-053-rw 053
Tried from win7 box and from Ubuntu 14.04 - same results. Definitely, something wrong with samba4... Tried to set
create mask = 0666
directory mask = 2775
force create mode = 774
force directory mode = 2774
newly created dir got permissions: drwxrwsr-x but copied file still got: -rwxr-xr--
Don't know what to do... Boss forces me to move to winserver to avoid such situations...
A.B.
  • 92,125
Troublemaker-DV
  • 358
  • 16
SOLVED (seems to be)
The problem was in the obey PAM restrictions parameter. By default it is turned off, and I could not remember why I turned it on. The SAMBA config was partially taken from older installation may be I had reasons to be obeyant there :-)
When it is ON, then SAMBA-created files are under UMASK restrictions. I don't know, if it is correctable via login defaults (what is the user?), but umask command gives me "0022" which means "u+a g-w o-w".
Hope, it will help to someone with similar problem.
Troublemaker-DV
  • 358
  • 16
