There are a ton of resources to which none of them are useful on how to install Apache 2.2 from Precise (12.04) on ubuntu trusty (14.04).
Can someone please help with a detailed answer of how to install Apache 2.2 on Ubuntu 14.04.
When I do an apt-cache there is no Apache 2.2.
When I add the sources, I then get Apache 2.2 but trying to install that does not work.
Apache 2.2 dependencies rely on apache2.2-common which relies on apache2.2-bin.
So I tried installing apache2.2-bin --> apache2.2-common --> apache2-mpm-worker then apache2={version}.
But every time after installation it tells me it failed. When I restart it tells me it failed and it could not read something out of the configuration file because it was missing.
Thank you in advance.
5 Answers5
How to install Apache 2.2 on an Ubuntu distro that does not have it in the repositories.
Requirements
You need to have the build-essentials package installed to do this.
~# sudo apt-get install build-essential
To give Apache the ability to compress output to browsers that support it, you need to install zlib. Download the current release from the zlip Hompage (zlib-1.2.11.tar.gz as of writing), extract it, navigate to the extracted folder, build, and install.
wget http://www.zlib.net/zlib-1.2.11.tar.gz
tar -xvf zlib-1.2.11.tar.gz
cd zlib-1.2.11/
./configure --prefix=/usr/local
make
sudo make install
Install Apache 2.2
Download the curent version from the Apache Download Page (httpd-2.2.32.tar.gz as of writing), extract it, navigate to the extracted folder, build, and install.
wget http://www-eu.apache.org/dist/httpd/httpd-2.2.32.tar.gz
tar -xvf httpd-2.2.32.tar.gz
cd httpd-2.2.32/
./configure --prefix=/usr/local/apache2 --enable-mods-shared=all --enable-deflate --enable-proxy --enable-proxy-balancer --enable-proxy-http
make
sudo make install
Start Apache:
sudo /usr/local/apache2/bin/apachectl start
Check, if everything is OK
Navigate to http://localhost in your browser, where you should see a message saying “It works!”.
Alterntively, you can do this via terminal:
wget -qO- http://localhost | grep "It works!"
Which should output something like this in the terminal:
<html><body><h1>It works!</h1></body></html>
Make Apache start at boot time
sudo cp /usr/local/apache2/bin/apachectl /etc/init.d/apachectl
sudo chmod +x /etc/init.d/apachectl
sudo sed -i '2i #\n### BEGIN INIT INFO\n# Provides:             apache2\n# Required-Start:       $remote_fs\n# Required-Stop:        $remote_fs\n# Default-Start:        2 3 4 5\n# Default-Stop:         0 1 6\n# Description:          apache2\n# Short-Description:    The Apache webserver\n### END INIT INFO' /etc/init.d/apachectl
sudo /usr/sbin/update-rc.d apachectl defaults
Hint: you can call apachectl with sudo service apachectl now.
Secure Apache
sudo service apachectl stop
sudo adduser --system apache
sed -i -e 's/User daemon/User apache/g' /usr/local/apache2/conf/httpd.conf
sed -i -e 's/Group daemon/Group nogroup/g' /usr/local/apache2/conf/httpd.conf
sudo service apachectl start
Check new settings
ps -aux | grep httpd
If the terminal output of the last command shows some lines starting with "apache" then everything is OK.
Configure your site(s)
If you want to configure your apache for just one site, simply edit the httpd.conf
nano /usr/local/apache2/conf/httpd.conf
The essential parameters you may want to modify are:
ServerName www.example.com:80
DocumentRoot "/usr/local/apache2/htdocs"
<Directory "/usr/local/apache2/htdocs">
    Options Indexes FollowSymLinks
    AllowOverride None
    Order allow,deny
    Allow from all
</Directory>
If you want to configure more than one site, have a look at httpd-vhosts.conf
nano /usr/local/apache2/conf/extra/httpd-vhosts.conf
You will have to add a < Directory > section withing the < VirtualHost > similar to the one above, but for the document root of the VitualHost. For example:
<VirtualHost *:80>
    ServerAdmin webmaster@dummy-host.example.com
    DocumentRoot "/usr/local/apache2/docs/dummy-host.example.com"
    ServerName dummy-host.example.com
    ServerAlias www.dummy-host.example.com
    ErrorLog "logs/dummy-host.example.com-error_log"
    CustomLog "logs/dummy-host.example.com-access_log" common
    <Directory "/usr/local/apache2/docs/dummy-host.example.com">
        AllowOverride None
        Order allow,deny
        Allow from all
    </Directory>
</VirtualHost>
MattSidor
  • 103
I managed to install it running the following command.
sudo apt-get install apache2=2.2.22-1ubuntu1.7 apache2.2-common=2.2.22-1ubuntu1.7 apache2.2-bin=2.2.22-1ubuntu1.7 apache2-mpm-worker=2.2.22-1ubuntu1.7
Thanks to this question here
Update: It seems like 2.2.22-1ubuntu1.7 does not exist any more. Please try using 2.2.22-1ubuntu1.10
With my original question I have since found the original problem while downgrading so did not look into this problem any further since then.
How to install Apache 2.2.34 (Ubuntu 14.04.x ... 16.04.4 or later):
  1. Install new zlib:
    cd zlib-1.2.11/
    make
    sudo make install
  2. Install apache 2.2.34:
    wget http://archive.apache.org/dist/httpd/httpd-2.2.34.tar.gz
    tar -xvf httpd-2.2.34.tar.gz
    cd httpd-2.2.34/
    make
    sudo make install
Enjoy!
As of Feb 2019, I did the following to install Apache 2.2 on Ubuntu 14.04:
Add old Repos to sources.list:
deb http://old-releases.ubuntu.com/ubuntu/ raring main restricted universe multiverse
deb-src http://old-releases.ubuntu.com/ubuntu/ raring main restricted universe multiverse
deb http://old-releases.ubuntu.com/ubuntu/ raring-updates main restricted universe multiverse
deb-src http://old-releases.ubuntu.com/ubuntu/ raring-updates main restricted universe multiverse
deb http://old-releases.ubuntu.com/ubuntu/ raring-backports main restricted universe multiverse
deb-src http://old-releases.ubuntu.com/ubuntu/ raring-backports main restricted universe multiverse
deb http://old-releases.ubuntu.com/ubuntu/ raring-proposed main restricted universe multiverse
deb-src http://old-releases.ubuntu.com/ubuntu/ raring-proposed main restricted universe multiverse
Used the command "apt-cache madison ^apache2 | grep "2.22" to find the appropriate version details
Then
  apt install apache2.2=2.2.22-6ubuntu5.1 apache2-mpm-worker=2.2.22-6ubuntu5.1 apache2.2-common=2.2.22-6ubuntu5.1
Commented out the modules not available, and went from there. I note that some of the modules needed to be installed - apt-cache madison ^libapache2 helped find them. Also I have issues with authz - presumably because I was not starting from a clean config.
davidgo
  • 149
  • 18
If the main reason you want to downgrade Apache to version 2.2 instead of using 2.3, 2.4 or higher is configuration compatibility, just install and enable mod_access_compat to ensure your old configs work as expected.
Do you want to install Apache 2.2 because some of the syntax for configs have changed beginning with Apache 2.3? I was scared of doing this myself at one point, but honestly it’s fairly straightforward how to change configs from old to new as explained here on the official Apache site.
But if you simply don’t have the time — or you are not really comfortable doing that — then look into using the mod_access_compat module. As explained on that page I linked to above:
Mixing old and new directives
Mixing old directives like Order, Allow or Deny with new ones like Require is technically possible but discouraged. mod_access_compat was created to support configurations containing only old directives to facilitate the 2.4 upgrade. Please check the examples below to get a better idea about issues that might arise.
I would recommend installing Apache 2.4 but enable mod_access_compat and then — if and when time is available — go through the Apache configs you have and “modernize” them to use Apache 2.4 compatible config options.
