I've got a 64GB SSD and a 3TB hard drive in my system running Ubuntu 14.04. The SSD has a small root partition with rest of the device allocated to an LVM physical volume. From that LVM physical volume I have two logical volumes allocated, one for /usr and one for /root. (/home is on the 3TB hard drive.)
Since I had about 25GB of the SSD currently unused, I thought it would be interesting to try using it as a bcache cache device with /home as backing device.
I created a new logical volume using the remaining space on the LVM physical volume on the SSD. That left things looking like this:
# pvs
  PV         VG   Fmt  Attr PSize  PFree
  /dev/sda2  VG4  lvm2 a--  53.57g    0
  /dev/sdb2  VG6  lvm2 a--   2.69t    0
# lvs
  LV      VG   Attr      LSize  Pool Origin Data%  Move Log Copy%  Convert
  VG4-usr VG4  -wi-ao--- 19.31g
  VG4-var VG4  -wi-ao---  9.31g
  bcache  VG4  -wi-ao--- 24.95g
  home    VG6  -wi-ao---  2.69t
I then did:
# make-bcache -C /dev/mapper/VG4-bcache
The system immediately locked up completely. (So the above is a reconstruction, I don't have the actual command I executed any more.)
Did I do something stupid without realising it? Is this a supported configuration? I'm wondering if it's worth reporting this as a bug or not. Nothing appears to have been permanently harmed by the crash.
saf
  • 35
I definitely think you should file a bug. I've never even thought about using a LV as bcache, only PV. And maybe (just maybe) you're the first one who's ever tried... And it's probably not handled...
Do you want me to proceed with a SysBck and try this myself? (Not today any more: too tired!)
Do you have a system backup??? (you're user type 4)
Fabby
  • 35,017
Yes it does. I accidently did my setup backwards. I set my lvm as the caching device and my ramdrive as the backing device. But yet, to answer your question it does work.
But I should mention that lvm2 has a caching feature, you might as well opt to use that (which is what I did) and then use bcache if you want to cache the lvm to ram
In my case, the problem was due to the device already being actively used in bcache, as confirmed by bcache-super-show.
$ make-bcache -B /dev/ssd/cache
Can't open dev /dev/ssd/cache: Device or resource busy
$ make-bcache -C /dev/ssd/cache
$ pvs
  /dev/mapper/md100-crypt hdd    lvm2 a--    3.64t 186.30g
  /dev/mapper/md101-crypt ssd    lvm2 a--  119.17g  32.23g
  /dev/md0                system lvm2 a--   13.81g   4.50g
$ lvs
  data  hdd    -wi-ao---  3.46t
  cache ssd    -wi-ao--- 29.75g
  data  ssd    -wi-ao--- 57.20g
  root  system -wi-ao—  9.31g
Seems to fail on the following
open("/dev/ssd/cache", O_RDWR|O_EXCL) = -1 EBUSY (Device or resource busy)
Before that failure, the following seems to succeed;
open("/dev/ssd/cache", O_RDONLY) = 4
ioctl(4, BLKSSZGET, 512) = 0
close(4)             = 0
This leads me to believe that O_EXCL is responsible for the EBUSY, indicating that perhaps another process is holding a lock on the device, however I can confirm that /dev/ssd/cache is not mounted, open or in use (as seen in lsof or fuser), and that rebooting does not resolve the problem.
Attempting to remove it from device-mapper also yields no progress;
$ dmsetup remove ssd-cache
device-mapper: remove ioctl on ssd-cache failed: Device or resource busy
So after running lsblk I can see the following;
sdb                        8:16   0 119.2G  0 disk
└─sdb1                     8:17   0 119.2G  0 part
  └─md101                  9:101  0 119.2G  0 raid1
    └─md101-crypt (dm-3) 252:3    0 119.2G  0 crypt
      ├─ssd-data (dm-4)  252:4    0  57.2G  0 lvm   /mnt/ssd/data
      └─ssd-cache (dm-5) 252:5    0  29.8G  0 lvm
        └─bcache0        251:0    0  29.8G  0 disk
As you can see, bcache0 is a child of the device in question, and a quick check confirms this;
$ bcache-super-show /dev/ssd/cache
sb.magic        ok
sb.first_sector     8 [match]
sb.csum         9F5D50331A2A10B9 [match]
sb.version      1 [backing device]
dev.label       (empty)
dev.uuid        8ba675a3-d9e4-4d47-8403-655c226f578f
dev.sectors_per_block   1
dev.sectors_per_bucket  1024
dev.data.first_sector   16
dev.data.cache_mode 0 [writethrough]
dev.data.cache_state    0 [detached]
cset.uuid       c006c316-d396-40cf-bde8-8bd4d0a017e8
Therefore, the root problem in my case was that the device itself was already part of bcache, and make-bcache failed to detect this.
Hopefully this will be useful to someone else in future.
SleepyCal
  • 101
