I can't fix the problem that happened when I have upgraded from Ubuntu 12.04 to 14.04.1 (apt-get dist-upgrade). I'm becoming crazy.
Copy from log:
>Start-Date: 2014-12-17  18:39:01
>Commandline: apt-get dist-upgrade
>Install: [..] libboost-graph-dev:amd64 (1.48.0.2), klogd:amd64 (1.5-6ubuntu1)
>Error: Sub-process /usr/bin/dpkg returned an error code (1)
>End-Date: 2014-12-17  18:40:19
Start-Date: 2014-12-17  18:41:51
Commandline: apt-get -f install
Upgrade: glib-networking-common:amd64 (2.32.1-1ubuntu2, 2.40.0-1), gvfs-common:amd64 (1.12.1-0ubuntu1.2, 1.20.1-1ubuntu1), libc6-dev:amd64 (2.15-0ubuntu15~ppa1, 2.19-0ubuntu6.4), gvfs:i386 (1.12.1-0ubuntu1.2, 1.20.1-1ubuntu1), libc-dev-bin:amd64 (2.15-0ubuntu15~ppa1, 2.19-0ubuntu6.4), glib-networking-services:amd64 (2.32.1-1ubuntu2, 2.40.0-1), libc6:amd64 (2.15-0ubuntu15~ppa1, 2.19-0ubuntu6.4), libc6:i386 (2.15-0ubuntu15~ppa1, 2.19-0ubuntu6.4), gvfs-daemons:amd64 (1.12.1-0ubuntu1.2, 1.20.1-1ubuntu1)
End-Date: 2014-12-17  18:41:55
Actually I can not upgrade or install or remove without have these errors:
~# apt-get upgrade
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these.
 glib-networking:i386 : Depends: glib-networking-services:i386 (>= 2.40.0-1)
                    Depends: glib-networking-common:i386 (= 2.40.0-1)
 gvfs:i386 : Depends: gvfs-libs:i386 (= 1.12.1-0ubuntu1.2) but 1.20.1-1ubuntu1 is installed
 gvfs-daemons : Depends: gvfs-libs (= 1.12.1-0ubuntu1.2) but 1.20.1-1ubuntu1 is installed
            Recommends: policykit-1-gnome but it is not installed
            Recommends: gvfs but it is not installed
 gvfs-libs : Depends: gvfs-common (= 1.20.1-1ubuntu1) but 1.12.1-0ubuntu1.2 is installed
 gvfs-libs:i386 : Depends: gvfs-common:i386 (= 1.20.1-1ubuntu1)
 libc-dev-bin : Depends: libc6 (> 2.19) but 2.15-0ubuntu15~ppa1 is installed
 libc6-dev : Depends: libc6 (= 2.19-0ubuntu6.4) but 2.15-0ubuntu15~ppa1 is installed
 libglib2.0-0 : Depends: libc6 (>= 2.17) but 2.15-0ubuntu15~ppa1 is installed
 libglib2.0-0:i386 : Depends: libc6:i386 (>= 2.17) but 2.15-0ubuntu15~ppa1 is installed
 libudev1 : Depends: libc6 (>= 2.17) but 2.15-0ubuntu15~ppa1 is installed
 libudev1:i386 : Depends: libc6:i386 (>= 2.17) but 2.15-0ubuntu15~ppa1 is installed
E: Unmet dependencies. Try using -f.
Adding -f, these are the only differences from the previous error:
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
E: Unable to correct dependencies
I had found that there were the older PPA and I updated it:
deb http://it.archive.ubuntu.com/ubuntu/ utopic main
deb-src http://it.archive.ubuntu.com/ubuntu/ utopic main
deb http://security.ubuntu.com/ubuntu utopic-security main
deb-src http://security.ubuntu.com/ubuntu utopic-security main
#deb http://it.archive.ubuntu.com/ubuntu/ utopic-updates main universe restricted multiverse
#deb-src http://it.archive.ubuntu.com/ubuntu/ utopic-updates main universe restricted multiverse
So I used the following command for each packet that was generating an error according to dpkg --configure -a:
echo "libc6-dev hold" | dpkg --set-selections
and this is the result:
# dpkg --get-selections | grep hold
desktop-file-utils                              hold
glib-networking:i386                            hold
gvfs-libs                                       hold
gvfs-libs:i386                                  hold
libc-dev-bin                                    hold
libc6-dev                                       hold
libgcrypt11-dev                                 hold
libglib2.0-0                                    hold
libglib2.0-0:i386                               hold
libglib2.0-bin                                  hold
libglib2.0-dev                                  hold
libgnutls-dev                                   hold
libpcre3-dev                                    hold
libpolkit-agent-1-0                             hold
libpolkit-gobject-1-0                           hold
libsecret-1-0                                   hold
libsecret-1-0:i386                              hold
libudev1                                        hold
libudev1:i386                                   hold
libudisks2-0                                    hold
udisks2                                         hold
But, again, I have the some problems with upgrade, install and remove. This is the only "strange" output that I have found:
# apt-get remove libc6-dev
You might want to run 'apt-get -f install' to correct these:
 build-essential : Depends: libc6-dev but it is not going to be installed or
                            libc-dev
 comerr-dev : Depends: libc6-dev but it is not going to be installed or
                       libc-dev
 e2fslibs-dev : Depends: libc6-dev but it is not going to be installed or
                         libc-dev
 gvfs:i386 : Depends: gvfs-libs:i386 (= 1.12.1-0ubuntu1.2) but 1.20.1-1ubuntu1 is to be installed
 gvfs-daemons : Depends: gvfs-libs (= 1.12.1-0ubuntu1.2) but 1.20.1-1ubuntu1 is to be installed
                Recommends: policykit-1-gnome but it is not going to be installed
                Recommends: gvfs but it is not going to be installed
 gvfs-libs : Depends: gvfs-common (= 1.20.1-1ubuntu1) but 1.12.1-0ubuntu1.2 is to be installed
 libblkid-dev : Depends: libc6-dev but it is not going to be installed or
                         libc-dev
 libbz2-dev : Depends: libc6-dev but it is not going to be installed or
                       libc-dev
 libc-dev-bin : Depends: libc6 (> 2.19) but 2.15-0ubuntu15~ppa1 is to be installed
 libcurl4-gnutls-dev : Depends: libc6-dev but it is not going to be installed or
                                libc-dev
 libexif-dev : Depends: libc6-dev but it is not going to be installed
 libexpat1-dev : Depends: libc6-dev but it is not going to be installed or
                          libc-dev
 libfreetype6-dev : Depends: libc6-dev but it is not going to be installed or
                             libc-dev
 libgcrypt11-dev : Depends: libc6-dev but it is not going to be installed or
                            libc-dev
 libglib2.0-0 : Depends: libc6 (>= 2.17) but 2.15-0ubuntu15~ppa1 is to be installed
 libglib2.0-0:i386 : Depends: libc6:i386 (>= 2.17) but 2.15-0ubuntu15~ppa1 is to be installed
 libgnutls-dev : Depends: libc6-dev but it is not going to be installed or
                          libc-dev
 libicu-dev : Depends: libc6-dev but it is not going to be installed or
                       libc-dev
 libjpeg-turbo8-dev : Depends: libc-dev
 libpcre3-dev : Depends: libc6-dev but it is not going to be installed
 libsasl2-dev : Depends: libc6-dev but it is not going to be installed
 libstdc++6-4.6-dev : Depends: libc6-dev (>= 2.13-0ubuntu6) but it is not going to be installed
 libtiff4-dev : Depends: libc6-dev but it is not going to be installed or
                         libc-dev
 libtool : Depends: libc6-dev but it is not going to be installed or
                    libc-dev
 libudev1 : Depends: libc6 (>= 2.17) but 2.15-0ubuntu15~ppa1 is to be installed
 libudev1:i386 : Depends: libc6:i386 (>= 2.17) but 2.15-0ubuntu15~ppa1 is to be installed
 libxft-dev : Depends: libc6-dev but it is not going to be installed or
                       libc-dev
 uuid-dev : Depends: libc6-dev but it is not going to be installed or
                     libc-dev
 zlib1g-dev : Depends: libc6-dev but it is not going to be installed or
                       libc-dev
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
I hope that some one can help me, I don't want to format :/ Cheers
You seem to have libc6, udev etc from ppas. Do you? These are just too fundamental for coming from outside ubuntu.
I expect you will have to get rid of these ppas [from sources.list etc] and try again
Rushi
  • 183
have you tried to
  • clear the apt cache apt-get clean
  • clear the error messages
  • edit your sources list file. vi /etc/apt/sources.list
After the source list file has been changed run
apt-get update
then try to upgrade/install packages
K7AAY
  • 17,705
One more thing to try is to upgrade the conflicting core packages. That is try
$ sudo apt-get upgrade libc6 libc6-dev libc-dev udev
This will likely give you a list of packages that this will remove. Its important that this list contains packages that came from ppas and not core packages like the above
[BTW It will help if you have synaptic and/or aptitude installed. If not dunno how to install now in a broken state :-( ]
Update
Just discovered here that you could try this awk command to list your obsolete/local packages
awk '/^Package: / {print $2}' /var/lib/dpkg/status | sort |
(awk '/^Package: / {print $2}' /var/lib/apt/lists/*_Packages | sort |
 comm -23 --nocheck-order /dev/fd/3 -) 3<&0
The list you get from that is probably the offending package list
Rushi
  • 183
