I would like to use ecryptfs to encrypt a random directory (i.e., not my home directory or a subdirectory thereof, principally due to disk space limitations on my home partition) and mount that directory when I log into my account. I can't see how to do this or even if it is really possible with the existing software. I have seen posts that provide vague suggestions (e.g., to use mount.ecryptfs_private with the ALIAS option), but I have yet to find simple, step-by-step instructions on how to do this. Would someone be able to provide these instructions or direct me to where to find them?
- 11,557
- 407
- 1
- 5
- 9
You're only looking at the the super-easy scripts like ecryptsfs-setup-private and ecryptsfs-mount-private, they use the more "generic" tools you seem to be looking for: mount.ecryptfs and ecryptfs-add-passphrase. See their man pages for more info.
And the link Rinzwind posted has all the info you need, further down the page under Manual Setup. They're quite long, but the very very short version would be:
The "Manual Setup" way (archlinux wiki)
First choose an ALIAS as you like. Through this section, ALIAS will be secret. Create the required directories/files:
$ mkdir ~/.secret ~/secret ~/.ecryptfs
$ touch ~/.ecryptfs/secret.conf ~/.ecryptfs/secret.sig
The ~/.secret directory will hold the encrypted data. The ~/secret directory is the mount point where ~/.secret will be mounted as an ecryptfs filesystem.
[Now create the actual mount passphrase (the easy scripts will pick a pseudo-random 32 characters from /dev/urandom), make it a good one]
$ echo "$HOME/.secret $HOME/secret ecryptfs" > ~/.ecryptfs/secret.conf
$ ecryptfs-add-passphrase
Passphrase:
Inserted auth tok with sig [78c6f0645fe62da0] into the user session keyring
Write the output signature (ecryptfs_sig) from the previous command to ~/.ecryptfs/secret.sig:
$ echo 78c6f0645fe62da0 > ~/.ecryptfs/secret.sig
A second passphrase for filename encryption may be used. If you choose so, add it to the keyring:
$ ecryptfs-add-passphrase Passphrase: Inserted auth tok with sig [326a6d3e2a5d444a] into the user session keyringIf you run the command above, append its output signature (ecryptfs_fnek_sig) to ~/.ecryptfs/secret.sig:
$ echo 326a6d3e2a5d444a >> ~/.ecryptfs/secret.sig
Finally, to mount ~/.secret on ~/secret:
$ mount.ecryptfs_private secret
To unmount ~/.secret:
$ umount.ecryptfs_private secret
Or you could really get your hands dirty yourself and follow the Without ecryptfs-utils directions.
Or if you already looked at the easy scripts
ecryptsfs-setup-private&ecryptsfs-mount-private, you might be able to copy those and edit them to point to your preferred directories, with a little bit of skill & patience.Or just store the passphrase(s) yourself somehow (securely preferably) and do like the
man ecryptfspage's example (must read the man pages):The following command will layover mount eCryptfs on /secret with a passphrase contained in a file stored on secure media mounted at /mnt/usb/. mount -t ecryptfs -o key=passphrase:passphrase_passwd_file=/mnt/usb/file.txt /secret /secret Where file.txt contains the contents "passphrase_passwd=[passphrase]".
Aside about encrypted home folders and an encrypted folder inside home - nested eCryptfs folders
And, an encrypted home folder normally stores files in /home/.ecryptfs/user/, while an encrypted Private folder has files inside your own home folder. You can not use both at the same time, eCryptfs will not do nested encrypted folders. But having an encrypted home, and encrypted folders outside of your home is ok.
I just tried creating a new user with an encrypted home
sudo adduser --encrypt-home jackIt created a
/home/.ecryptfs/folder, with:/home/.ecryptfs/jack/.ecryptfs/- wrapped passphrase & config files to automount jack's home on login/home/.ecryptfs/jack/.Private/- actual encrypted home files, mounted to/home/jack/when logged in.And also the
/home/jack/folder, but it contained a link that stays there whether logged in or not:/home/jack/.ecryptfs/ -> /home/.ecryptfs/jack/.ecryptfsNext I logged in as jack, but the link was still there, so trying to run
ecryptfs-setup-privatecaused it to look in/home/jack/.ecryptfs/but really see the existing files in/home/.ecryptfs/jack/.ecryptfsso it failed to create another password file & fail withERROR: wrapped-passphrase file already exists, use --force to overwrite.Trying the "ALIAS" steps above, using a .secret folder inside the encrypted home failed, with these errors:
Mount on filesystem of type eCryptfs explicitly disallowed due to known incompatibilities
Reading sb failed; rc = [-22]"Nesting encrypted directories inside of encrypted directories is not supported with eCryptfs. Sorry." - eCryptfs author & maintainer
Changing the ALIAS folder outside of jack's home, trying
/tmp/.secret/&/tmp/secret/works. BUT if jack log's out the new encrypted folder will stay mounted, so you have to unmount it (umount.ecryptfs_private secret).
If you want to use it like encfs you can do it with the following entry in /etc/fstab
/tmp/.geheim /tmp/geheim ecryptfs rw,no_sig_cache,ecryptfs_fnek_sig=1f7aefb9e239099f,ecryptfs_cipher=aes,ecryptfs_key_bytes=32,ecryptfs_enable_filename_crypto=y,ecryptfs_passthrough=n,passphrase_passwd=geheimpw,user,noauto 0 0
geheim is the german-word for secret, but ensures that it's not a keyword. You must create the directories first. The first-time you should leave ecryptfs_fnek_sig=1f7aefb9e239099f away. Then mount /tmp/geheim will show you the correct value.
You can store the password at other place and set more sophisticated options. You will find all options in man ecryptfs.
- 248
ecryptfs /destination/to/encrypted/storage /destination/to/seeing/unencrypted/data
e.g:
ecryptfs /home/$USER/EFILES /home/$USER/Downloads/RANDOMDIRECTORY
use the commmand above to create and mount encrypted system where files saved in RANDOMDIRECTORY are encrypted and saved to EFILES.
additional notes. make sure RANDOMDIRECTORY is empty when you begin. Once you run the command above, and the system is mounted and ready to go, any files that you save in RANDOMDIRECTORY will be encrypted in to EFILES if the system is mounted. For a quick moount/unmount you can either create a bash script, and run it through an app shortcut, or create an alias command for quick mounting.
I've been using this for more than a year now.
EDIT: went home to confirm, thy command is not ecryptfs. its encfs i.e.
encfs /destination/encrypted /destination/unencrypted
sorry about that. With this you will have to install a new program tho (probably)
