I'm new to ubuntu, does it come with a firewall installed or will I have to install one, if so which one is best.
Asked
Active
Viewed 1,176 times
Your question looks really broad, however just to mention that "Ubuntu has pre installed firewall and a Set of Rules what so called "IPTABLES".
You can do
sudo ufw status#this gives you the status if firewall is active or inactive
or
sudo ufw enable#enables the firewall
or
sudo ufw -h #displays all possible options
To enable the firewall just type sudo ufw enable ssh #this will enable firewall for ssh.
You can add some rules using iptables Command
sudo iptables -L -n#will list available rules for IPTABLES such as (INPUT, OUTPUT,NAT,etc.)
heavyguidence
- 1,671
