The dedicated steam key on my ASUS ROG G751 laptop does not do anything. What do I need to do to make it launch steam?
Update: This will make the "video" button and the "rog" button next to the keypad also launch steam. Will look into that when I have the time.
This is how I made the "Steam button" work on my ASUS ROG G751. I would not be surprised if there is a simpler way to do this :) I am using xbindkeys to bind the steam key to a script. The script will start steam if it is not already running. If steam is running the script will change focus to steam. To achieve this I am using xdotool.
Install xbindkeys:
sudo apt-get xbindkeys
sudo apt-get xbindkeys-config
xbindkeys --defaults > ~/.xbindkeysrc
Run:
xbindkeys-config
Add a new item with: Name: Steam, Key: Mod2 + NoSymbol | m:0x10 + c:248, or you can use the "Get Key" function. We want to execute a script as Action: ~/opensteam This script will start steam if not started. Change focus to steam if started.
Install xdomod
sudo apt-get install xdotool
Script (opensteam):
nano ~/opensteam
Enter this into nano:
#!/bin/bash
if [ -n "$(tail /var/log/kern.log -n 1 | grep 'key 7f pressed')" ]; then
if [ -z "$(xdotool search --name steam)" ]; then
echo "Focus"
steam &
else
echo "Execute"
xdotool search --name steam windowactivate
fi
else
echo "Steam key was not pressed"
fi
Make opensteam executable
chmod a+x opensteam
Open "startup applications" either via the menu or via command:
gnome-session-properties
In startup applications add: Name, command and comment: xbindkeys
This will make the xbindkeys launch when you log in. It runs in the background.
Edit: Added a nasty hack to fix the issue where the ROG key and the video key also started steam.
- 51
