I downloaded a few themes from various ppa's, and i don't like the button for closing, minimalizing etc. Are those themes stored in some kind of directory where i can edit their files? I'm using Unity Tweak Tool for applying them. Thank you!
Asked
Active
Viewed 2.2k times
Default themes directory is /usr/share/themes/ but it's editable only for root. If You want to edit themes the default directory for current user would be ~/.themes/ I believe.
kcpr
- 1,472
locate themes|grep Ambiance| grep png|more
/usr/share/themes/Ambiance/gtk-3.0/assets/backdrop-button-active-disabled.png
/usr/share/themes/Ambiance/gtk-3.0/assets/backdrop-button-active-hover.png
/usr/share/themes/Ambiance/gtk-3.0/assets/backdrop-button-active.png
/usr/share/themes/Ambiance/gtk-3.0/assets/backdrop-button-disabled.png
/usr/share/themes/Ambiance/gtk-3.0/assets/backdrop-button-hover.png
/usr/share/themes/Ambiance/gtk-3.0/assets/backdrop-button-toolbar-active.png
/usr/share/themes/Ambiance/gtk-3.0/assets/backdrop-button-toolbar.png
/usr/share/themes/Ambiance/gtk-3.0/assets/backdrop-button.png
/usr/share/themes/Ambiance/gtk-3.0/assets/backdrop-check-mixed-alt.png
/usr/share/themes/Ambiance/gtk-3.0/assets/backdrop-check-mixed-disabled-alt.png
/usr/share/themes/Ambiance/gtk-3.0/assets/backdrop-check-mixed-disabled.png
/usr/share/themes/Ambiance/gtk-3.0/assets/backdrop-check-mixed-hover-alt.png
/usr/share/themes/Ambiance/gtk-3.0/assets/backdrop-check-mixed-hover.png
You can find the others in the same directory /usr/share/themes/ with their respective names.
Rinzwind
- 309,379
If you want to find out the location of some app, file or anything else in the terminal type:
whereis 'name_you_search' - for example ''whereis firefox''
It will give you the directory in which the file is located.
When you type ''whereis themes'' you should get something like this:
themes: /usr/share/themes
So the themes are inside /usr/share directory
Muzaffar
- 5,677
