I want to use the graphviz package on an Ubuntu system, but according to the build log it is configured using --without-gts, whereas I want GTS support to be included (I don't know if there's a reason why it isn't, or if it's just an arbitrary decision).
What's the best way to go about doing this? Ideally I want to keep my build as close as possible to the one shipped in Ubuntu, as that would make it easier to get the change merged in at a later date. I'm struggling to find any guides which show how to do this - they all seem to assume you want to package new software from scratch.
pwaring
  • 123
The general procedure for changing build options for an Ubuntu/Debian package goes like this:
  1. Get the build dependencies
  2. Download the source package
  3. Change the appropriate files (usually debian/rules)
  4. Commit changes
  5. Build the packages
  6. Install the packages
The commands involved:
sudo apt-get build-dep graphviz
apt-get source graphviz
cd graphviz-* # Or check the directory with ls and pick the correct version
Then you can delete the configuration option from debian/rules, either using an editor, or:
sed -i '/--without-gts/d' debian/rules
This command is specific to this instance, as there is only one match for --without-gts in debian/rules.
Depending on what changes were made, a commit with a message is required or an error will occur during the build step.
dpkg-source --commit
Then build the package:
dpkg-buildpackage -us -uc
This will create a bunch of packages in the parent directory. The options indicate the you don't wish to make a package for uploading to the Ubuntu repositories (and so don't want to sign them, etc.). Now you can install these packages:
sudo dpkg -i ../*.deb # or pick out the packages manually
The build dependencies may be different from the installation dependencies, so to install all the dependencies you might need to run:
sudo apt-get install -f
Utkonos
  • 179
muru
  • 207,228
