I have acidently removed some libraries from system and now I does not install or remove any package. Error shown in Software center and in terminal is
installArchives() failed: Can't exec "locale": No such file or directory at /usr/share/perl5/Debconf/Encoding.pm line 16.Use of uninitialized value $Debconf::Encoding::charmap in scalar chomp at /usr/share/perl5/Debconf/Encoding.pm line 17.
Can't exec "locale": No such file or directory a /usr/share/perl5/Debconf/Encoding.pm line 16.
Use of uninitialized value $Debconf::Encoding::charmap in scalar chomp at/usr/share/perl5/Debconf/Encoding.pm line 17.
Can't exec "locale": No such file or directory at/usr/share/perl5/Debconf/Encoding.pm line 16.
dpkg: warning: 'ldconfig' not found in PATH or not executable
dpkg: error: 1 expected program not found in PATH or not executable
Note: root's PATH should usually contain /usr/local/sbin, /usr/sbin and /sbin
Error in function:
When using apt-get install anyPackage and apt-get install -f anyPackage i get the following error:
Reading package lists... Done
Building dependency tree Reading state information... Done
You might want to run 'apt-get -f install' to correct these.
cups : Depends: libc-bin (>= 2.13) E: Unmet dependencies. Try using -f
Alvar
  • 17,038
May problem has been sesolved. I have installed the conflicting package.
Solution
Download and extract the package manually
apt-get download libc-bin
dpkg -x libc-bin*.deb unpackdir/
Copy the file to your system
sudo cp unpackdir/sbin/ldconfig /sbin/
Make sure the package and package system is in a good state.
sudo apt-get install --reinstall libc-bin
sudo apt-get install -f
for original source click here!
