I installed Wine 1.7.13 from PlayOnLinux to run Origin client on my Ubuntu 14.04. But the menu shows two tabs with Wine(x86) versions and Wine(amd64) versions.
Can anyone explain the difference between the two?
Which version is more reliable for gaming?
SY_13
  • 486
  • 22
x86 denotes 32-bit machine architecture.
amd64 denotes 64-bit machine architecture.
Depends.
x86 is reliable for 32-bit games.
amd64 is reliable for 64-bit games.
Postscript:
amd64 is commonly referred to as x64. The previously used 64-bit version was designed by the Intel corp which was called as x86-64. It was not compatible with the native x86 instruction set. In 2003, AMD introduced the perfect 64-bit version for the x86 instruction set. Since they introduced it, it is named after them as amd64. Hope you would have enjoyed the history :)
Ramvignesh
  • 1,862
  • 20
  • 31
Because AMD was the first to develop a 64-bit processor, we still call a 64-bit version "AMD64" today although there are more Intel 64-bit processors today then AMD ones.
"x86" is for 32 bit machines only.
So which is "more reliable for gaming", depends on the game: 32 bit or 64-bit?
Fabby
  • 35,017
Ken Mollerup
  • 1,315
  • Wine x86 will ONLY run 32 bits programs.
  • Wine x64 will ONLY run 64 bits programs.
Most of x64 programs come with x32 version, so, for better compatibility you may preffer it.
