I have a lenovo laptop with ubuntu 14.04 (64 bit) installed on it. It has Intel® Core™ i3-3110M CPU @ 2.40GHz × 4 processor, 4 GiB ram and Nvidia 635 M graphics card. The system works fine under normal operations but it lags, stuck a lot during copying files. Earlier I was using 13.10 and no such problem was with with. Any help would be appreciated.
Sunil Kumar
  • 83
Just do these things
sudo -H gedit /etc/sysctl.conf
Now add these lines at the end of this file
vm.dirty_background_ratio = 5
vm.dirty_ratio = 10
Now save and exit
Then again type in terminal:
sudo sysctl -p
Press enter and whoaaa! It's done: no more lag.
muru
  • 207,228
Looking at the top output you provided in the comments you have one problem (not enough cache memory) that can be divided into two sub-problems:
  1. chromium.
  2. compiz
The cheap solution:
  1. Easiest to solve. Chromium is known to be a memory hog: uninstall it and use FireFox instead.
  2. A bit more complex to solve.
    a. Make a system backup! If you don't know how, read What's a good backup strategy for 1 PC (You've now officially become user type 4 instead of being user type 3)
    b. sudo apt-get install compizconfig-settings-manager (aka CCSM)
    c. Go to the dash and type "Compiz" and the CCSM icon should come up.
    d. And now it's up to you: turn off anything you don't use! E.g. if you don't use multiple desktops, turn off "Expo" and "Desktop wall" (and that's why you have to take a back-up: you're on your own here; I don't know what you use and what not)
The expensive solution
Buy more RAM. Double it (at least). :-(
Fabby
  • 35,017
I found that disabling the transparent huge pages feature does help.
Check if it is enabled:
cat /sys/kernel/mm/transparent_hugepage/enabled
  • enabled: [always] madvise never
  • disabled: always madvise [never]
To disable do:
sudo su -c 'echo never >/sys/kernel/mm/transparent_hugepage/enabled'
To [re]enable do:
sudo su -c 'echo always >/sys/kernel/mm/transparent_hugepage/enabled'
More info at: https://access.redhat.com/solutions/46111
Amadu Bah
  • 146
