Warning: Take your time reading this first sentence:
Before typing the following keystroke, remember that Ctrl+Alt+F7 is your friend. This is the keystroke to type to get back to where you are right now. (probably your guest session) OK? Remember? Sure?
OK! Now press Ctrl+Alt+F1 to go to TTY1, which is a full screen terminal (and only a terminal: no mouse, no dash, no nothing). Try to log in there.
It does show your user name when you type it after the login: prompt, but does not show anything when you type your password! Oh, and you have to type Enter after you typed your user name and before it shows you the password prompt.
Now type the following commands: (assuming "jam" is your old user name)
sudo adduser jam2
and follow the instructions on-screen. If you're not on a US keyboard, don't use any "special" characters like £ à ŷ ü nor any numbers unless they're from your keypad.
sudo adduser jam2 adm
sudo adduser jam2 cdrom
sudo adduser jam2 sudo
sudo adduser jam2 dip
sudo adduser jam2 plugdev
sudo adduser jam2 lpadmin
sudo adduser jam2 sambashare
(If any of the above gives an error like group not found, don't worry: I'm trying to be thorough)
Now, log out of the guest session and log in as "jam2" and come back here to this site and "accept" the answer by clicking on the little grey check-mark below the "0" to the left of this answer, thereby accepting the answer as valid and the next person asking the same kind of question will be able to use it as well.
Done? OK?
Now,
- open the file manager
- browse to the
/home/jam directory
- copy (not move!) all the files from Downloads to
/home/jam2/Downloads
- check you did a good job.
- Now delete
/home/jam/Downloads
- Go back to step 3 and repeat for Documents, Videos, ...
Done!
