I am mounting a Windows 7 Home Premium 64-bit system partition on my Ubuntu 14.04.1 LTS 64-bit installation in order to be able to share data between the two OSs. The problem is that although I explicitly give the option permissions in /etc/fstab file I cannot chmod the files or directories inside the mounted drive. I also experimented with it and noticed if I only supplied permissions option while mounting(after unmounting everything) it and changed into the mount directory I noticed that everything had chmod 777 permissions, but I was able to alter the permission via the chmod command. The command is as follows in the command prompt:
mount -t ntfs-3g -o permissions /dev/sda5 /mnt/DATA/
However, I noticed even when I supplied my uid and gid to own the files the option permissions stopped having an effect. I tried appending and prepending it into the list of options just to make sure, and it turned out that in both cases I was not able to alter the permissions with chmod. The codes I used in command prompt is as follows:
sudo mount -t ntfs-3g -o uid=1000,gid=1000,permissions /dev/sda5 /mnt/DATA/
After unmounting, one more try as follows:
sudo mount -t ntfs-3g -o permissions,uid=1000,gid=1000 /dev/sda5 /mnt/DATA/
Both of these configurations did not allow me to change the settings and the option permissions had literally no effect. In my /etc/fstab file I define the line for mounting the NTFS partition as follows:
# data was on /dev/sda5 always
UUID=01CCA0086DD8A980 /mnt/DATA ntfs auto,users,uid=1000,gid=1000,dmask=022,fmask=133,permissions 0 0
How can I make permissions options work so that I can change the permissions on the go without having to remount the partition totally? I read somewhere in this website it as possible, but I am unsure of how to do it. I would greatly appreciate any comments suggestions on this issue. My full /etc/fstab is as follows:
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
# / was on /dev/sda6 during installation
UUID=c6cc14c0-aa75-4660-9e45-10a8fadedb64 / ext4 errors=remount-ro 0 1
# /home was on /dev/sda8 during installation
UUID=30c60dd5-3c79-4e36-8ed7-d8035422f0b6 /home ext4 defaults 0 2
# swap was on /dev/sda7 during installation
UUID=ffbc51d4-25b3-413f-aed1-14eba0f769c7 none swap sw 0 0
