10
I installed the deb files of Fpdb (a poker analysis tool); and i downloaded the program. The problem is that when i try to run it from the terminal i get this: "ImportError: No module named pygtk "; I tried to re install and update pygtk but i can't solve the problem.
thanks in advance for any suggestion;
c
Eric Carvalho
  • 55,453
charlizard
  • 111
This means the program you are running is looking for a particular python library called pygtk, which allows your program to have a gui. So, to let the program work, you need to install pygtk:
sudo apt-get install python-gtk2-dev
That should do it.
IronManMark20
  • 269
