I have a new AOC e1649WU DisplayLink usb monitor, but when I plugged this into my Fujitsu laptop running on Ubuntu 14.04, it remains black and in Utility, after hitting detect displays, no additional display is detected. On windows, it works fine after installing DisplayLink's drivers. I am relatively new to Linux, would appreciate it if I just follow the answer posted in this question? link (I am not sure if it is applicable to Ubuntu 14) with the package downloaded from here.
I am just hoping to get an extended display setting up dual monitors.
Here is some information about my system:
enter code here
> uname -a
Linux schoen-mind 3.13.0-43-generic #72-Ubuntu SMP Mon Dec 8 19:35:06 UTC 2014 x86_64 x86_64 x86_64 GNU/Linux
> xrandr
Screen 0: minimum 8 x 8, current 1366 x 768, maximum 16384 x 16384
VGA-0 disconnected (normal left inverted right x axis y axis)
LVDS-0 connected primary 1366x768+0+0 (normal left inverted right x axis y axis) 322mm x 181mm
1366x768       60.0*+
HDMI-0 disconnected (normal left inverted right x axis y axis)
DVI-D-0 disconnected (normal left inverted right x axis y axis)
> dmesg
[   71.631022] usb 1-1.2: Product: e1649Fwu
[   71.631027] usb 1-1.2: Manufacturer: DisplayLink
[   71.631031] usb 1-1.2: SerialNumber: DZRE8HA026443
[   71.633268] hid-generic 0003:17E9:4107.0004: hiddev0,hidraw3: USB HID v1.10 Device [DisplayLink e1649Fwu] on usb-0000:00:1a.0-1.2/input1
[   71.712080] [drm] vendor descriptor length:17 data:17 5f 01 00 15 05 00 01 03 00 04
[   71.810818] open /dev/fb0 user=0 fb_info=ffff8800acde1000 count=1
[   71.810949] Console: switching to colour frame buffer device 170x48
[   71.810958] udl 1-1.2:1.0: fb0: udldrmfb frame buffer device
[   71.810960] udl 1-1.2:1.0: registered panic notifier
[   71.810964] [drm] Initialized udl 0.0.1 20120220 on minor 1
[   71.811194] usbcore: registered new interface driver udl
[ 2035.345665] systemd-hostnamed[3060]: Warning: nss-myhostname is not installed. Changing the local hostname might make it unresolveable. Please install nss-myhostname!
> lspci -k | grep -A 2 -i "VGA"
01:00.0 VGA compatible controller: NVIDIA Corporation GF119M [GeForce GT 520M] (rev a1)
Subsystem: Fujitsu Limited. Device 1635
Kernel driver in use: nvidi
Are there additional commands output I should post here? Recommendations is much appreciated!! Thank you.
PacbeanRainer
  • 61
On Aug 3, 2015, Displaylink finally released the USB Monitor driver for Ubuntu.
Link: http://www.displaylink.com/downloads/ubuntu.php
I have an AOC usb monitor and Ubuntu 14.04. After installing the driver, my usb Monitor start working.
If the driver works for your monitor, please let other people know by posting it. Many people waiting for this driver. I've been waiting for 2 years. :-)
Unfortunatly DisplayLink hardware is still incompatible with most linux distros. https://bbs.archlinux.org/viewtopic.php?id=151463
Dean
