I'm new here, and I'm not very good at tech.... So help me here. The drivers I downloaded from Nvidia's website won't install, even after I boot into TERMINAL ONLY. After
sudo gdm stop
It doesn't do anything, but only says
could not recognize name; bailing out
or something like that. After I run the nvidia.run driver file, it says I need to remove XServer HELP PLEASE!
Ben Yan
  • 33
GT540M is an NVIDIA Optimus card. Those do not work by default. See also Is a NVIDIA GeForce with Optimus Technology supported by Ubuntu?
Now, you shouldn't have installed the drivers from nVidia's website. If you're using a new installation, I recommend doing a clean install. Otherwise, jump into a terminal and run the below command to uninstall the nvidia driver:
sudo sh NVIDIA* --uninstall
(NVIDIA* is actually NVIDIA-Linux-x86*-..run)
To make use of your nvidia card, you could use Bumblebee. Within a few days, a new stable release should be available. Please do not install it from mj-casalogic/bumblebee PPA as it can break your system.
Lekensteyn
  • 178,446
Sounds like you need to install the proprietary drivers provided by Nvidia for your card. If you are unsure how to do that here is a quick and easy tutorial I found Easy way to Install Proprietary Drivers in Ubuntu
... Go to System Settings, and click on something like "Extra hardware drivers" or "Restricted drivers". It should automatically detect wich driver you need. Just choose it from the list, click the Activate button, and reboot your computer.
RobinJ
  • 9,020
