I'm new to Linux and have just started using Ubuntu.
I'm trying to install QtScript Generator. Here is what it's README says:
Step 1:
Build the generator: cd path/to/this/project/generator, qmake && make
Done.
Step 2:
Run the generator (without arguments) This will generate C++ files in path/to/this/project/generated_cpp and documentation in path/to/this/project/doc
How do I run the generator file?
Thanks in advance.
Girish
After running make, an executable called generator is created inside the source directory (the one you are in at this point). To execute it, type
./generator
The ./ is necessary because the shell by default looks for executables only in directories found in the $PATH environment variable. The ./ tells it to look inside the current directory.
Cmdr
  • 209
