I have encountered a strange problem after upgrading my kernel in ubuntu 14.04, mainly the touchpad scrolling stopped working. After spending some time on debuging I came to a conclusion that synaptics driver is not loaded. This are the clues that make me think so:
1) touchpad is detected
$ xinput -l
⎜ ↳ PS/2 Synaptics TouchPad id=12 [slave pointer (2)]`
2) no trace of 'synaptics' driver in Xorg.0.log:
$ cat /var/log/Xorg.0.log | grep synaptics
is empty
3) finally in the same log file I found line which states:
[ 34.046] (II) Using input driver 'evdev' for 'PS/2 Synaptics TouchPad'
which is quite straightforward. I have tried purging and reinstalling xserver-xorg-input-synaptics with no good effect. Also config file /usr/share/X11/xorg.conf.d/50-synaptics.conf look OK to me as it contains:
Section "InputClass"
Identifier "touchpad catchall"
Driver "synaptics"
MatchIsTouchpad "on"
# This option is recommend on all Linux systems using evdev, but cannot be
# enabled by default. See the following link for details:
# http://who-t.blogspot.com/2010/11/how-to-ignore-configuration-errors.html
MatchDevicePath "/dev/input/event*"
EndSection
what may be a little strange is that my system possesses copy of this file located in /etc/X11/xorg.conf.d
of course I am not able to change anything from graphical mode (Settings->Mouse and Touchpad) as there are no options there.
Does anyone have an idea why does my system ignore config file 50-synaptics.conf and uses evdev as driver?
EDIT: kernel I use now is 3.13.0-43-generic. last time the touchpad worked correctly was with 3.13.0-29-generic
