I have installed ubuntu on my pen drive and now I can boot from my pendrive. Now I want the same to be done for MINT. So can I install MINT on the same pendrive along with UBUNTU? Pendrive size 32GB.
Asked
Active
Viewed 68 times
You can install as many different live distros as you like on a pendrive using Multisystem.
It is very well maintained, and there are frequent automatic updates once you have the repositories installed.
You can get the source here:
http://sourceforge.net/projects/multisystem/
But you can also install and keep it updated it via Ubuntu package manager by downloading the following, extracting it and running it as root (be warned!):
http://liveusb.info/multisystem/install-depot-multisystem.sh.tar.bz
The only thing is that you will have to start with a freshly-formatted USB, then use Multisystem to install Ubuntu and Mint. However it will mean you won't have to manually configure Grub2 yourself, which would be another way to do things.
harlandski
- 221
