I'm having trouble downloading steam to Ubuntu, his is my first time trying this I have a Google Chromebook and i tried to YouTube how to download steam and i pretty much have it, but it says that i'm missing some files steam needs in order to download. I've tried everything i don't know what to do or what i'm doing honestly. I need some help
Asked
Active
Viewed 49 times
Open the terminal and try with the following things,
pushd /tmp
sudo apt-get install -y curl wget && \
wget -E http://media.steampowered.com/client/installer/steam.deb && \
sudo dpkg -i steam.deb ; \
sudo apt-get install -yf && \
After installing please use exit command,
exit
Hope the above helps.
BDRSuite
- 3,196
- 1
- 13
- 11
Please just go to the Ubuntu Software Center and install steam that way. It is painless and I've never seen it fail. I suspect it may require you to uninstall what you've already installed, but hopefully you can do that from the software center as well,
gyropyge
- 2,568
