My "Most Frequently Used" Applications in Unity Dash disappeared.
I tried to:
  • reset unity with unity --reset,
  • removing Zeitgeist history with rm ~/.local/share/zeitgeist/activity.sqlite, and even
  • reinstall zeitgeist via Synaptic,
but no one worked.
I also used Guest Session to check whether it only disappeared in my account, but actually not.
I don't know why it happened. How can I get it back? How do we reinstall unity and zeitgeist so that they really return to the state as when they are freshly installed?
Thanks in advance.
muru
  • 207,228
Inoe
  • 337
Finally, found the solution myself ^^
I had another problem with file search, and tried to completely remove and reinstall the components of unity and zeitgeist many times but it didn't help. So I tried something else and found the solution.
Simply delete the ~/.local/share/zeitgeist folder (not just activity.sqlite), and restart the computer. It will generate a new and fresh zeitgeist folder, and the dash will be normal again.
Note: Just for safety reasons, I chose to rename the zeitgeist folder to zeitgeist.bak instead of completely deleting it, in case things didn't go as intended, because this was actually just a trial and success attempt :)
belacqua
  • 23,540
Inoe
  • 337
