-1
I've recently immigrated to Ubuntu and I don't know that much about it.i would be thankful if you could tell me step by step how to add ruby and python to Ubuntu 14.10. thanks
hsbr13
  • 101
Python comes as an inbuilt package in Ubuntu. To run a Python script, open up your terminal and change to the directory where you have your Python code.
Now type:
python <your_filename>.py
To run Ruby code, you need to install the Ruby package. To install it, type the following code in the terminal:
sudo apt-get install ruby
After installing, to check if Ruby is installed correctly,type:
ruby - v
If this shows your Ruby version, you have successfully installed Ruby.
To run Ruby code, type :
ruby <your_filename>.rb
grooveplex
  • 2,506
  • 27
  • 35
