I try to run -
$ jhbuild sysdeps --install
but run into the broken packages error.
Here is the complete log- http://pastebin.com/ZaV34510
I am on Ubuntu 14.04 64-bit. I am following this guide to build gnome- https://wiki.gnome.org/GnomeLove/BuildGnome
I debugged errors like these in the past by repeatedly removing the older packages until all dependencies were met.
But now I get a much longer list of package problems, which removing manually would be infeasible.
Any help will be appreciated.
Mitch
  • 109,787
goelakash
  • 387
First list all the packages which is having conflict by using the following command,
apt-mark showhold
After doing so unhold by using the below command,
sudo apt-mark unhold <package name>
Once you are done with the above remove all the packages which is causing the issue and re-install it again. Hope this will help you to fix the issue. Please give it a try.
BDRSuite
  • 3,196
  • 13
