I have a 3TB seagate protable hard drive (SATA), but this hard drive suddenly has really low performance. I guess there are some bad blocks in the hard drive.
So I have done this test:
  1. Plugin the hard drive directly into a desktop.
  2. Run Ubuntu 14.04 from a bootable usd stick.
  3. Create a partition of 100 MB and formatted into ext2.
sudo mkfs.ext2 -c -c /dev/sdc1
  1. Test the performance of the new partition.
sudo hdparm -t /dev/sdc1
However, the performance is really low for this partition and unstable.
/dev/sdc1 Timing buffered disk reads: 2 MB in 15.86 seconds = 129.16 kB/sec
What should I do to improve the performance of my hard drive?
Thanks for any suggestions.
Bangyou
  • 201
Odds are you're having read errors due to a failing disk. Before anything else, back up your data and get ready to replace the drive.
That said, if you want to get some use out of this drive, you could use badblocks to force the drive to replace the bad sectors with spare ones:
sudo badblocks -wsv /dev/sdc
Or if you want to keep the data on the drive, use a non-destructive test as described in this answer:
sudo badblocks -nsv /dev/sdc
Note: both badblocks and using fsck -vcck will stress a drive and can make a bad drive die faster. Do not rely on this for data recovery. But if you want to get some extra use out of a drive you were going to throw away, give this a shot.
