I documented my research as a bash script as a gist based on the official doc
Compiling and Installing libsass and sassc
Install dependencies
apt-get install automake libtool
Fetch sources
git clone https://github.com/sass/libsass.git
git clone https://github.com/sass/sassc.git libsass/sassc
Create configure script
cd libsass
autoreconf --force --install
cd ..
Create custom makefiles for shared library
For more info read: Difference between static and shared libraries? before installing libsass.
cd libsass
./configure \
--disable-tests \
--enable-shared \
--prefix=/usr
cd ..
Build the library
make -C libsass -j5
Install the library
sudo make -C libsass -j5 install
Testing
Only node-sass
time node-sass /path/to/main.scss
Succeed with
Rendering Complete, saving .css file...
Wrote CSS to /mnt/data/projects/EVRPA/evrpa/web/main.css
node-sass ../web/styles/main.scss 0.42s user 0.03s system 95% cpu 0.471 total
Gulp with ruby-sass
[17:48:21] Using gulpfile /mnt/data/projects/EVRPA/evrpa/web/gulpfile.js
[17:48:21] Starting 'css'...
[17:48:21] gulp-ruby-sass: directory
[17:48:23] gulp-ruby-sass: overwrite main.css
[17:48:24] Finished 'css' after 2.9 s
gulp css 4.60s user 0.35s system 46% cpu 10.605 total
Gulp with node-sass
time gulp css
[17:47:59] Using gulpfile /mnt/data/projects/EVRPA/evrpa/web/gulpfile.js
[17:47:59] Starting 'css'...
[17:48:00] Finished 'css' after 1.1 s
gulp css 2.99s user 0.20s system 100% cpu 3.164 total
Conclusion
My tests are no benchmark and have little value but node-sass seems to be 3-5x faster than ruby-sass.
