I'll let the .gif I have do most of the talk: The GIF
A bit of backstory: I have 100 PNG files (which can be seen here on imgur), each one is a frame of an animation. With those files, I have to make a .gif.
I used:
To make the gif linked above.
Basically, as the question says, the previous image loaded stays on the next frame, and so on until the gif is over. I want to know if it's possible to make a gif where this does not happen. If possible, a command line answer is preferred.
Zanna
  • 72,312
Vicyorus
  • 163
I assume you're using http://www.imagemagick.org/. The -dispose command describes what is to be done with the frame after its delay (when the next frame is loaded). Info here: http://www.imagemagick.org/Usage/anim_basics/#dispose
-dispose previous
try:
mcissel
  • 104
