first of all merry christmas to everyone.
I wanted to ask you a basic question. I installed a software, in this case Eclipse 3.8 through the following command:
sudo apt-get install eclipse
And the terminal told me :
After this operation, 236 MB of additional disk space will be used.
Do you want to continue? [Y/n] Y
When I want to remove it I do :
sudo apt-get remove eclipse
and the terminal gives me : After this operation, 125 kB disk space will be freed. Do you want to continue? [Y/n] Y
My question is: how can I delete all the files I downloaded before?
Thanks in advance.
desmond13
  • 924
  • 17
If you would like to remove all the downloaded packages which done using either Terminal or Ubuntu Software Center, you could use the command sudo apt-get clean. If you want to remove everything of the installed packages, you could use the command sudo apt-get purge {package_name}, in your case, sudo apt-get purge eclipse.
Wolverine
  • 664
