I use Ubuntu 14.10 virtual machine in headless mode and access it using ssh. But many a times it gets stuck on GRUB boot loader screen and I have to log in to the VM in graphical mode and restart in headless mode. But after some time this problem resurfaces, mainly when VM is not shutdown properly.
So I would like to set the timeout of the boot loader screen to a very low value for the cases when VM is not closed properly.
You can read the full documentation here. In general it is two steps:
  1. Edit the file /etc/default/grub as root (or with sudo) and set the GRUB_TIMEOUT variable to whatever you want.
  2. Make the changes visible by calling sudo update-grub
halirutan
  • 274
  • 16
