I was trying to change the name of my portable HDD from terminal. usually the rename command is used or sometimes mv.
I am getting this error.
/media/dishank$ rename virus\ BOX/ virus_box virus\ BOX/
Search pattern not terminated at (eval 1) line 1.
αғsнιη
  • 36,350
man -k label | grep -E 'file|volume'
should print the names of a few relevant shell commands.
Check out the man pages.
You will probably need to prepended with sudo as you attempt to run any of them.
NOTE:
rename - renames multiple files
rm - remove files or directories
mv - move files
Hannu
  • 6,605
  • 28
  • 45
I followed following steps:
  1. Need to find the path of media device. mine was /dev/sdc1 (use Gparted to find)
  2. unmount the partition (do not disconnect it physically). ex: sudo umount /dev/sdc1
  3. mine is ntfs so. sudo ntfslabel /dev/sdc1 virus_box and mount back your device.
  4. verify changes through sudo blkid
All is done.
For more info link
αғsнιη
  • 36,350
