I installed ubuntu netbook edition on my netbook* expecting to get the best performance out of it, but apparently, that didn't turn out.
Unity is a bit slow on it, and when I click on Files and folders it takes a while to load the respective interface and the bar at the top disappears and then loads in.
Is this expected? Is there anything I can do to improve the performance? Is this problem specific to my netbook?
*Netbook info:
Acer - Aspire One
1.6 GHz Intel Atom Processor
1 GB RAM Memory
Intel GMA 950 graphics card
Severo Raz
  • 6,111
6 Answers6
Installing Unity 2D might work better on your hardware, it's the supported fallback desktop.
Jorge Castro
  • 73,717
A specific answer to your 'files and folders being slow' query is that this is a known issue in Nautilus. To see this really in action open /usr/lib or /usr/bin. Basically nautilus has this feature where to looks to identify file types, etc, and this can take a while, specially on slow spinning disks.
One fix here is to change your file manager to pcmanfm, which is a lightweight file manager and skips the file lookup stuff that nautilus does. This thread should outline how-to - http://ubuntuforums.org/showthread.php?t=692238
Your desktop will still be rendered via nautilus, but you can change all other filemanager actions to this filemanager, and have lookups be speedy.
Anil
  • 13
I have some problems with Acer Aspire One which are coming from fact that SSD drive in this netbook is very cheap and slow. I guess, that is not necessary Unity fault that everything is slow.
There are many tips about performance of Ubuntu on this hardware.
It is said that Zeitgeist is slowing unity animations and increase cpu usage.
Zeitgeist is a service which logs the users's activities and events, anywhere from files opened to websites visited and conversations. It makes this information readily available for other applications to use in the form of timelines and statistics.
You can remove zeitgeist easily, but don't remove libzeitgeist-XXX if you use unity :
sudo apt-get purge zeitgeist zeitgest-core zeitgeist-datahub
yilmi
  • 1,282
May be this is not an answer that you expect, but you can try some other Ubuntu distros like Xubuntu and Lubuntu (still in beta).
Not really an answer, but more of a work around...
1) Log off 2) Click on your Username 3) Set the session to "Ubuntu Desktop Edition" 4) Complete log in
The you'll be running normal Ubuntu, which should be snappier than Unity.
FYI, I'm also experiencing really bad performance with Unity. It's a shame because it's a nice interface!
